addeswe
Alternative to at scheduler
Tue Mar 29, 2016 1:08 pm
Hi. I want to run a software at random times and for this, at would be the perfect solution. My only problem is that it runs all scripts with the shell /bin/sh. And most stuff I write is in Python3. So is there a way to set Python3 as the shell, or is there any alternative? And no. I don't want to use crontab for random. :-)
Thanks in advance.
“Knock, knock.” - “Who’s there?” - very long pause…. - “Java.”
If a python knocks on your door and says “Hi, I’m a vacuum cleaner!” it’s not true. That’s a python.
jbudd
Re: Alternative to at scheduler
Tue Mar 29, 2016 1:55 pm
Make the first line of your script
#! /usr/bin/python3
Then the script will be executed by the Python interpreter not bash.
addeswe
Tue Mar 29, 2016 3:46 pm
Well... that's not really true. :-(
[[email protected]][/tmp] more test.py
#!/usr/bin/python3
with open('/tmp/thisisanewfile.txt','w') as file:
    file.write('This is working?!')
[[email protected]][/tmp] at 17:38 -M -f /tmp/test.py
warning: commands will be executed using /bin/sh
job 2 at Tue Mar 29 17:38:00 2016
tpylkko
Tue Mar 29, 2016 3:50 pm
are you running these programs on Raspbian? If so, you can use systemd timers with random time.
Tue Mar 29, 2016 4:13 pm
Just because the AT command says it's running stuff with /bin/sh doesn't mean it won't use the shebang line once /bin/sh has read the python program and tried to execute it. Here's an example run on Raspbian Jessie
[email protected] ~/python $ cat for.at.py
#!/usr/bin/python3
    file.write('Is this working from AT?')
[email protected] ~/python $ at 17:12
at> /home/pi/python/for.at.py
at> <EOT>
job 17 at Tue Mar 29 17:12:00 2016
[email protected] ~/python $ date
Tue 29 Mar 17:12:03 BST 2016
[email protected] ~/python $ cat /tmp/thisisanewfile.txt
Is this working from [email protected] ~/python $
This is a doctor free zone.
addeswe
Tue Mar 29, 2016 7:07 pm
Well ain't that a treat. Thanks DougieLawson for setting me on the right path.
Answer if somebody else experience the same problem:
You can't write it on one line: at 21:12 -M -f /tmp/whatever.py. This throws an error since it uses /bin/sh to execute whatever the shebang is.
Solution: See previous post from Dougie OR echo /tmp/whatever.py | at 21.12 -M
Thanks again for the support.
