BST Clock Changing
Posted: Sun Mar 27, 2016 11:00 am
by RDS
I have a Pi running continuously but I noticed that the time has not gone forward by an hour overnight. I don't really want to stop the program that is running but is there something that I should have done to ensure it picks up BST time changes or does that only happen if the system is rebooted.
Re: BST Clock Changing
Posted: Sun Mar 27, 2016 11:12 am
by fruitoftheloom
RDS wrote:I have a Pi running continuously but I noticed that the time has not gone forward by an hour overnight. I don't really want to stop the program that is running but is there something that I should have done to ensure it picks up BST time changes or does that only happen if the system is rebooted.
sudo raspi-config
Check the TimeZone etcetera settings are correct under Internationalisation Options, changes will need a reboot...
Posted: Sun Mar 27, 2016 11:25 am
by DirkS
I think it should have picked it up if the TZ was set correctly.
I checked my Pi and one of them was not correct. I'm fairly sure I did not change the TZ on that one.
I ran raspi-config and set it to Europe / London and it was changed without reboot.
Posted: Sun Mar 27, 2016 12:21 pm
by RDS
@fruitoftheloom
Thank you. I have run that and set to Europe/London rebooted and it now shows correct time.
@DirkS
Thanks but I had to reboot mine to get it to show the correct time.
I will check my other 2 Pi's next time they are running.
