sfe2me
sending data from raspberry
Thu Mar 24, 2016 5:00 pm
I have a temperature sensor I want to send the data to an html file in a django project
sprinkmeier
Re: sending data from raspberry
Fri Mar 25, 2016 12:39 am
There are many possible solutions. More information about the project could help narrow the scope a little.
A somewhat generic solution would be to use espeak in a loop called from a script to voice the data. Use trained homing-pigeon/parrot crossbreeds to memorise and deliver the data. A speech-to-text engine will be able to convert the data back to enable it to be posted on your django.
Bellisarius
Fri Mar 25, 2016 1:23 am
sfe2me wrote:I have a temperature sensor I want to send the data to an html file in a django project
First thing to is to tell people where the django project is being hosted. On the same Pi, on another computer on the local network, or on a remote webserver.
Bellisarius
Fri Mar 25, 2016 1:26 am
sprinkmeier wrote:Use trained homing-pigeon/parrot crossbreeds to memorise and deliver the data. A speech-to-text engine will be able to convert the data back to enable it to be posted on your django.
RFC 1149 describes a far more efficient way of using Avian carriers, and it has been successfully implemented and tested.
https://tools.ietf.org/html/rfc1149
java
Fri Mar 25, 2016 2:04 pm
http://www.news24.com/SciTech/News/Pige ... m-20090909
Substantiated as above.
It does happen
sfe2me
Mon Apr 04, 2016 11:27 am
the django project is on the same Pi
