guangong
Raspberry Pi 3 B: dmesg OK?
Sun Mar 20, 2016 4:38 pm
Is the dmesg OK? especially with
[ 2.133153] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040ecc0
[ 2.146988] WARN::hcd_init_fiq:413: FIQ ASM at 0x8040f030 length 36
[ 2.161358] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
**** dmesg ****
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.18-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #846 SMP Thu Feb 25 14:22:53 GMT 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80876f80, node_mem_map b9bb4000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @bafb0000 s20416 r8192 d20544 u49152
[ 0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa22082 bcm2709.serial=0x1521820 smsc95xx.macaddr=B8:27:EB:52:18:20 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939416K/966656K available (6024K kernel code, 534K rwdata, 1660K rodata, 448K init, 757K bss, 19048K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807895a0 (7686 kB)
.init : 0x8078a000 - 0x807fa000 ( 448 kB)
.data : 0x807fa000 - 0x8087fac0 ( 535 kB)
.bss : 0x80882000 - 0x8093f79c ( 758 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000026] Switching to timer-based delay loop, resolution 52ns
[ 0.000240] Console: colour dummy device 80x30
[ 0.001282] console [tty1] enabled
[ 0.001334] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001403] pid_max: default: 32768 minimum: 301
[ 0.001724] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001768] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002773] Initializing cgroup subsys blkio
[ 0.002821] Initializing cgroup subsys memory
[ 0.002870] Initializing cgroup subsys devices
[ 0.002913] Initializing cgroup subsys freezer
[ 0.002963] Initializing cgroup subsys net_cls
[ 0.003033] CPU: Testing write buffer coherency: ok
[ 0.003119] ftrace: allocating 20309 entries in 60 pages
[ 0.048644] CPU0: update cpu_capacity 1024
[ 0.048708] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.048743] [bcm2709_smp_prepare_cpus] enter
[ 0.048893] Setting up static identity map for 0x8240 - 0x8274
[ 0.050642] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.050979] [bcm2709_secondary_init] enter cpu:1
[ 0.051024] CPU1: update cpu_capacity 1024
[ 0.051030] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.051404] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.051659] [bcm2709_secondary_init] enter cpu:2
[ 0.051681] CPU2: update cpu_capacity 1024
[ 0.051687] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.052042] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.052227] [bcm2709_secondary_init] enter cpu:3
[ 0.052247] CPU3: update cpu_capacity 1024
[ 0.052253] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.052315] Brought up 4 CPUs
[ 0.052413] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.052442] CPU: All CPU(s) started in HYP mode.
[ 0.052468] CPU: Virtualization extensions available.
[ 0.053166] devtmpfs: initialized
[ 0.071430] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.071696] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.072546] pinctrl core: initialized pinctrl subsystem
[ 0.073090] NET: Registered protocol family 16
[ 0.078225] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.079191] bcm2709.uart_clock = 48000000
[ 0.083230] bcm2709: Mini UART enabled
[ 0.083298] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.083345] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.083516] Serial: AMBA PL011 UART driver
[ 0.083660] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.084085] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.149385] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.149457] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.150045] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.150082] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.150649] SCSI subsystem initialized
[ 0.150857] usbcore: registered new interface driver usbfs
[ 0.150963] usbcore: registered new interface driver hub
[ 0.151079] usbcore: registered new device driver usb
[ 0.151614] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-25 14:25
[ 0.178707] Switched to clocksource arch_sys_counter
[ 0.220160] FS-Cache: Loaded
[ 0.220440] CacheFiles: Loaded
[ 0.229686] NET: Registered protocol family 2
[ 0.230648] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.230789] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.231000] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.231113] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.231182] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.231504] NET: Registered protocol family 1
[ 0.231822] RPC: Registered named UNIX socket transport module.
[ 0.231854] RPC: Registered udp transport module.
[ 0.231882] RPC: Registered tcp transport module.
[ 0.231910] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.232864] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.233945] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.247307] VFS: Disk quotas dquot_6.6.0
[ 0.247633] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.249746] FS-Cache: Netfs 'nfs' registered for caching
[ 0.250664] NFS: Registering the id_resolver key type
[ 0.250726] Key type id_resolver registered
[ 0.250754] Key type id_legacy registered
[ 0.252811] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.252968] io scheduler noop registered
[ 0.253007] io scheduler deadline registered (default)
[ 0.253308] io scheduler cfq registered
[ 0.255559] BCM2708FB: allocated DMA memory fa800000
[ 0.255606] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.282138] Console: switching to colour frame buffer device 228x61
[ 0.297537] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.301404] console [ttyS0] disabled
[ 0.301520] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[ 1.495288] console [ttyS0] enabled
[ 1.501922] vc-cma: Videocore CMA driver
[ 1.508341] vc-cma: vc_cma_base = 0x00000000
[ 1.516069] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.524922] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.533921] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.558740] brd: module loaded
[ 1.570674] loop: module loaded
[ 1.576650] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[ 1.589501] Loading iSCSI transport class v2.0-870.
[ 1.598140] usbcore: registered new interface driver smsc95xx
[ 1.607609] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.817325] Core Release: 2.80a
[ 1.822487] Setting default values for core params
[ 1.830365] Finished setting default values for core params
[ 2.039838] Using Buffer DMA mode
[ 2.045260] Periodic Transfer Interrupt Enhancement - disabled
[ 2.054820] Multiprocessor Interrupt Enhancement - disabled
[ 2.063955] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.071162] Dedicated Tx FIFOs mode
[ 2.077150] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[ 2.093276] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 2.133103] dwc_otg: Microframe scheduler enabled
[ 2.175321] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.187577] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.203674] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 2.216931] Init: Port Power? op_state=1
[ 2.227452] Init: Power Port (0)
[ 2.237025] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.252306] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.268296] usb usb1: Product: DWC OTG Controller
[ 2.280156] usb usb1: Manufacturer: Linux 4.1.18-v7+ dwc_otg_hcd
[ 2.294110] usb usb1: SerialNumber: 3f980000.usb
[ 2.306413] hub 1-0:1.0: USB hub found
[ 2.316662] hub 1-0:1.0: 1 port detected
[ 2.327471] dwc_otg: FIQ enabled
[ 2.327481] dwc_otg: NAK holdoff enabled
[ 2.327489] dwc_otg: FIQ split-transaction FSM enabled
[ 2.327523] Module dwc_common_port init
[ 2.327788] usbcore: registered new interface driver usb-storage
[ 2.341814] mousedev: PS/2 mouse device common for all mice
[ 2.355617] bcm2835-cpufreq: min=600000 max=1200000
[ 2.367918] sdhci: Secure Digital Host Controller Interface driver
[ 2.382104] sdhci: Copyright(c) Pierre Ossman
[ 2.393566] sdhost: log_buf @ ba813000 (fa813000)
[ 2.478743] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.514154] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.518811] Indeed it is in host mode hprt0 = 00021501
[ 2.540226] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 2.588822] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.602545] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.603547] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.606880] mmc0: new high speed SDHC card at address aaaa
[ 2.607346] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 2.611788] mmcblk0: p1 p2 < p5 p6 p7 >
[ 2.629337] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.630884] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.632431] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.635237] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.708743] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.708877] Indeed it is in host mode hprt0 = 00001101
[ 2.747497] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.760510] usbcore: registered new interface driver usbhid
[ 2.773586] usbhid: USB HID core driver
[ 2.784253] Initializing XFRM netlink socket
[ 2.785516] mmc1: new high speed SDIO card at address 0001
[ 2.808067] NET: Registered protocol family 17
[ 2.819363] Key type dns_resolver registered
[ 2.830680] Registering SWP/SWPB emulation handler
[ 2.843059] registered taskstats version 1
[ 2.853853] vc-sm: Videocore shared memory driver
[ 2.865456] [vc_sm_connected_init]: start
[ 2.876380] [vc_sm_connected_init]: end - returning 0
[ 2.909029] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.910365] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 2.910411] VFS: Mounted root (ext4 filesystem) readonly on device 179:7.
[ 2.921245] devtmpfs: mounted
[ 2.921981] Freeing unused kernel memory: 448K (8078a000 - 807fa000)
[ 2.979038] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.995408] hub 1-1:1.0: USB hub found
[ 3.005596] hub 1-1:1.0: 5 ports detected
[ 3.282967] random: systemd urandom read with 79 bits of entropy available
[ 3.288750] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.319769] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 3.346007] systemd[1]: Detected architecture 'arm'.
[ 3.389037] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.404540] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.423438] smsc95xx v1.0.4
[ 3.491809] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:52:18:20
[ 3.497785] NET: Registered protocol family 10
[ 3.499258] systemd[1]: Inserted module 'ipv6'
[ 3.506036] systemd[1]: Set hostname to <raspberrypi>.
[ 3.788770] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[ 3.929705] usb 1-1.4: New USB device found, idVendor=15ca, idProduct=00c3
[ 3.945459] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 3.949520] systemd[1]: Expecting device dev-ttyS0.device...
[ 3.975504] usb 1-1.4: Product: USB Optical Mouse
[ 3.993248] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.010455] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.027376] systemd[1]: Starting Remote File Systems (Pre).
[ 4.044820] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:15CA:00C3.0001/input/input0
[ 4.045161] hid-generic 0003:15CA:00C3.0001: input,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.4/input0
[ 4.094470] systemd[1]: Reached target Remote File Systems (Pre).
[ 4.109295] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 4.134360] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.154579] systemd[1]: Starting Encrypted Volumes.
[ 4.173253] systemd[1]: Reached target Encrypted Volumes.
[ 4.187127] systemd[1]: Starting Swap.
[ 4.203966] systemd[1]: Reached target Swap.
[ 4.216016] systemd[1]: Expecting device dev-mmcblk0p6.device...
[ 4.236598] systemd[1]: Starting Root Slice.
[ 4.254453] systemd[1]: Created slice Root Slice.
[ 4.267122] systemd[1]: Starting User and Session Slice.
[ 4.286681] systemd[1]: Created slice User and Session Slice.
[ 4.301106] systemd[1]: Starting Delayed Shutdown Socket.
[ 4.308743] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
[ 4.336721] systemd[1]: Listening on Delayed Shutdown Socket.
[ 4.351299] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 4.373146] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.389595] systemd[1]: Starting Journal Socket (/dev/log).
[ 4.409757] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.424526] systemd[1]: Starting udev Control Socket.
[ 4.444108] systemd[1]: Listening on udev Control Socket.
[ 4.458019] systemd[1]: Starting udev Kernel Socket.
[ 4.477039] systemd[1]: Listening on udev Kernel Socket.
[ 4.490668] systemd[1]: Starting Journal Socket.
[ 4.503042] usb 1-1.5: New USB device found, idVendor=0e8f, idProduct=0022
[ 4.519149] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.519161] usb 1-1.5: Product: USB KB V11
[ 4.519168] usb 1-1.5: Manufacturer: GASIA
[ 4.564629] systemd[1]: Listening on Journal Socket.
[ 4.577551] systemd[1]: Starting System Slice.
[ 4.591406] input: GASIA USB KB V11 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:0E8F:0022.0002/input/input1
[ 4.619360] systemd[1]: Created slice System Slice.
[ 4.632317] systemd[1]: Starting File System Check on Root Device...
[ 4.648988] hid-generic 0003:0E8F:0022.0002: input,hidraw1: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-3f980000.usb-1.5/input0
[ 4.680332] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 4.700270] input: GASIA USB KB V11 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:0E8F:0022.0003/input/input2
[ 4.726331] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.742223] systemd[1]: Starting system-autologin.slice.
[ 4.759009] hid-generic 0003:0E8F:0022.0003: input,hidraw2: USB HID v1.10 Device [GASIA USB KB V11] on usb-3f980000.usb-1.5/input1
[ 4.787231] systemd[1]: Created slice system-autologin.slice.
[ 4.801772] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 4.822552] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.837933] systemd[1]: Starting Increase datagram queue length...
[ 4.861756] systemd[1]: Starting Restore / save the current clock...
[ 4.929510] systemd[1]: Started Set Up Additional Binary Formats.
[ 4.945393] systemd[1]: Mounting Debug File System...
[ 4.968334] systemd[1]: Starting udev Coldplug all Devices...
[ 4.992667] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.089416] systemd[1]: Starting Load Kernel Modules...
[ 5.115559] systemd[1]: Mounted Huge Pages File System.
[ 5.130275] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.154743] systemd[1]: Starting Slices.
[ 5.174666] systemd[1]: Reached target Slices.
[ 5.198311] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.220268] systemd[1]: Mounted Debug File System.
[ 5.237529] fuse init (API version 7.23)
[ 5.252224] systemd[1]: Started Increase datagram queue length.
[ 5.302433] systemd[1]: Started Restore / save the current clock.
[ 5.328253] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 5.355767] i2c /dev entries driver
[ 5.361275] systemd[1]: Time has been changed
[ 5.386519] systemd[1]: Started udev Coldplug all Devices.
[ 5.408258] systemd[1]: Started File System Check on Root Device.
[ 5.431253] systemd[1]: Started Load Kernel Modules.
[ 5.577292] systemd[1]: Starting Apply Kernel Variables...
[ 5.600357] systemd[1]: Mounting FUSE Control File System...
[ 5.624473] systemd[1]: Mounting Configuration File System...
[ 5.648597] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 5.658237] systemd[1]: Starting Syslog Socket.
[ 5.665031] systemd[1]: Listening on Syslog Socket.
[ 5.665228] systemd[1]: Starting Journal Service...
[ 5.680409] systemd[1]: Started Journal Service.
[ 5.847493] systemd-udevd[108]: starting version 215
[ 6.826038] cfg80211: Calling CRDA to update world regulatory domain
[ 6.943523] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[ 6.945376] usbcore: registered new interface driver brcmfmac
[ 7.145852] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[ 7.154802] random: nonblocking pool is initialized
[ 7.174163] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 7.243059] bcm2835-rng 3f104000.rng: hwrng registered
[ 7.244183] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 7.503452] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 7.503481] cfg80211: World regulatory domain updated:
[ 7.503490] cfg80211: DFS Master region: unset
[ 7.503499] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.503515] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.503527] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.503539] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.503554] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.503568] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.503581] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.503593] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.503606] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 12.009874] EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
[ 12.329841] systemd-journald[106]: Received request to flush runtime journal from PID 1
[ 12.702281] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 12.702303] brcmfmac: brcmf_add_if: ignore IF event
[ 15.551611] uart-pl011 3f201000.uart: no DMA platform data
[ 16.459914] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 16.460076] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.339171] Bluetooth: Core ver 2.20
[ 22.339218] NET: Registered protocol family 31
[ 22.339223] Bluetooth: HCI device and connection manager initialized
[ 22.339238] Bluetooth: HCI socket layer initialized
[ 22.339247] Bluetooth: L2CAP socket layer initialized
[ 22.339266] Bluetooth: SCO socket layer initialized
[ 24.005046] Bluetooth: HCI UART driver ver 2.3
[ 24.005059] Bluetooth: HCI UART protocol H4 registered
[ 24.005064] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 24.005069] Bluetooth: HCI UART protocol BCM registered
[ 26.207200] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
[ 26.349738] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 26.349754] Bluetooth: BNEP filters: protocol multicast
[ 26.349770] Bluetooth: BNEP socket layer initialized
[ 37.740694] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
DirkS
Re: Raspberry Pi 3 B: dmesg OK?
Mon Mar 21, 2016 12:53 am
Those 3 lines are warnings, not errors.
I get the same, and everything is working fine. I wouldn't worry about.
java
Mon Mar 21, 2016 10:06 am
Don't have a RPi 3, yet, but do not see anything for cause to be alarmed about, expect that to be a normal boot up sequence, few warnings but no errors as DirkS noted.
