Running GUI based C++ app on raspberry pi
Posted: Fri Mar 18, 2016 8:07 am
by Arooj Waqar
I am new at raspberry pi. I have this GUI based C++ application created using visual studio. I want to run that application on raspberry pi. How can I do it ?
Thank you !
Re: Running GUI based C++ app on raspberry pi
Posted: Fri Mar 18, 2016 9:31 am
by RogerW
Arooj Waqar wrote:I am new at raspberry pi. I have this GUI based C++ application created using visual studio. I want to run that application on raspberry pi. How can I do it ?
Thank you !
It depends what GUI framework you used. If you used MFC then I suspect you will have to start again. If you used a framework supported by Linux then you could be in luck.
