WolfG
Pi 3 wlan
Thu Mar 17, 2016 11:58 am
Greetings!
After installing Raspbian on a new Pi3 I checked wlan0 for existing SSIDs.
A few were visible plus the wifi accesspoint of my LAN.
For several reasdions I reinstalled Raspbian but since then I cannot see my SSID anymore.
Other SSID's are visible, so the wlan works so far, however my SSID is not visible.
Another wifi device placed right next to pi 3 receives my WLAN w/o issues, so a dead spot is not the problem.
I placed Pi3 a few feet next to the access point, but without success, my SSID is not visible.
Changing 'Region' (TP-Link Archer C20i dual band) from 'Austria' to 'United States', my SSID is visible with Link Quality=61/70 Signal level=-49 dBm.
However, the 5Ghz band is not visible.
US Region allows up to 1W, most EU countries up to 100mW.
Is it possible that the pi3 wlan chip (BCM43143) is defect?
Thanks fore reading and hints.
Wolf
DirkS
Re: Pi 3 wlan
Thu Mar 17, 2016 12:24 pm
WolfG wrote:However, the 5Ghz band is not visible.
AFAIK 5GHz is not supported by Pi3B internal wifi
BTW: have you set the correct wifi country code with
sudo raspi-config
, section Internationalisation Options?
WolfG
Re: Pi 3 wlan
Thu Mar 17, 2016 4:15 pm
Changing to 'AT' did not solve the issue :cry: .
Re: Pi 3 wlan
Fri Mar 18, 2016 6:45 am
Connect a wired LAN, run sudo apt-get update && sudo apt-get upgrade && sudo reboot there's a newer WiFi driver in the raspberrypi-bootloader package that you'll get by doing that.
I'll do your homework for you for a suitable fee.
WolfG
Re: Pi 3 wlan
Fri Mar 18, 2016 10:48 am
I updated as you suggested, but no success.
Still works only with US setting.
The strange thing is that I can see other SSIDs but not my access point.
Another wlan device, placed right next to raspi, receives a good signal (4 bars) from my ap.
Perhaps i have to replace this RasPi3.
Thanks for your time.
Wolf
WolfG
Re: Pi 3 wlan
Sat Mar 19, 2016 10:29 am
Reading Zosima's post Thu Mar 10, 2016 3:07 pm 'Raspberry Pi 3 can not detect my wifi'
I changed the channel from auto to 9 and the wlan is visible.
And yes, ch 11+12 are nor working.
So I think this this is a sw issue and wait for a new driver :)
Thanks for your time,
Wolf
Re: Pi 3 wlan
Sat Mar 19, 2016 7:35 pm
Have you used sudo raspi-config to set your WiFi country code?
WolfG
Re: Pi 3 wlan
Tue Mar 22, 2016 7:18 am
I updated the firmware with
sudo rpi-update 41f8b4812ad653abf321b8c54cb4bee57ebdb129
as explained by blacai in
viewtopic.php?f=91&t=139550&sid=dc0271
This solves the issue for me.
Thank you very much for your time.
Wolf
zealousd
Re: Pi 3 wlan
Tue Mar 22, 2016 7:41 am
what about using an external usb wifi adapter?
Raspberry Pi 3
Ubuntu Mate
Web Server
DirkS
Re: Pi 3 wlan
Tue Mar 22, 2016 8:50 am
zealousd wrote:what about using an external usb wifi adapter?
Why would you use an external wifi dongle if you have a built-in one?
markkulix
Re: Pi 3 wlan
Fri Apr 01, 2016 5:20 pm
I got my pi3 working with rasbian with those instructions channels 12 & 13 , thank you!
But I like to use archlinux and would like to get channels 12 & 13 to work.
Archlinux sees only channels 1-11.
/M
DirkS
Re: Pi 3 wlan
Fri Apr 01, 2016 10:29 pm
markkulix wrote:But I like to use archlinux and would like to get channels 12 & 13 to work.
See https://wiki.archlinux.org/index.php/Wi ... ory_domain
Return to “Beginners”
