terrible
Raspberry Pi 3
Tue Mar 15, 2016 12:36 pm
So I am a noob. I have managed to run Raspberry Pi 2 with Moode and an external HDD for streaming music through DLNA. I was more than delighted to hear the sound I get. Which prompted me to get Pi 3. I have a few problems with this. I get a rainbow screen. I don't know what you mean by kernel. So please do tell me what goes wrong here. The sd card has volumio and runs perfectly with Pi 2. However, on Pi 3, when connected to my TV screen through HDMI, I get a rainbow screen. Would be grateful if you could guide me through this.
Another question I have is, why can't I run the Pi on my Mac OS or Bootcamp (Windows 8.1) when connected through HDMI? Or does it need to be connected in some other way?
Thank you.
Cognac
Re: Raspberry Pi 3
Tue Mar 15, 2016 12:45 pm
Rainbow screen is the result of not enough power.
Buy a 2,5A power adaptor for your Pi3.
terrible
Re: Raspberry Pi 3
Tue Mar 15, 2016 12:59 pm
Cognac wrote:Rainbow screen is the result of not enough power.
You mean the power supply adapter 5V 2A micro USB charger that I am using for Raspi 2 will not work?
klricks
Re: Raspberry Pi 3
Tue Mar 15, 2016 1:04 pm
terrible wrote:So I am a noob. I have managed to run Raspberry Pi 2 with Moode and an external HDD for streaming music through DLNA. I was more than delighted to hear the sound I get. Which prompted me to get Pi 3. I have a few problems with this. I get a rainbow screen. I don't know what you mean by kernel. So please do tell me what goes wrong here. The sd card has volumio and runs perfectly with Pi 2. However, on Pi 3, when connected to my TV screen through HDMI, I get a rainbow screen. Would be grateful if you could guide me through this.
The large 'rainbow' means the boot file are not compatible. Put the card in the RPi 2 and do an update.
sudo apt-get update
sudo apt-get upgrade
Note if you used NOOBS or are running an old Raspbian Wheezy then the update may not work. You will need to do a fresh Raspbian Jessie install.
The small rainbow square in the top right means that the voltage of the power supply is too low and/or the USB power cable is poor quality.
terrible wrote: Another question I have is, why can't I run the Pi on my Mac OS or Bootcamp (Windows 8.1) when connected through HDMI? Or does it need to be connected in some other way?
Thank you.
If you are trying to connect the HDMI to your laptop then that won't work. Most HDMI ports are output only.
RaTTuS
Contact: Twitter YouTube
Re: Raspberry Pi 3
Tue Mar 15, 2016 1:06 pm
you need a new image for the RPi-3
if you boot to command-line on RPi2 then you can upgrade like :-
sudo apt-get update && sudo apt-get upgrade -y
if it is some other distribution then you may need to install the latest version from their site
Covfefe
Burngate
Re: Raspberry Pi 3
Tue Mar 15, 2016 3:47 pm
EDITED: eyesight ain't what it used to be!
Re: Raspberry Pi 3
Tue Mar 15, 2016 3:57 pm
Though you state 5V2A it may not be accurate, the RPi 3B by default draws more power, therefore if the power supply is not actually producing a good stable voltage it can cause the issue. Your screen shot is showing the small top right rainbow square low power indicator...
Re: Raspberry Pi 3
Tue Mar 15, 2016 3:58 pm
Double check the lead if you still have power problems after the upgrade. I use a 2A device no problems.
terrible
Re: Raspberry Pi 3
Tue Mar 15, 2016 6:29 pm
klricks wrote:The large 'rainbow' means the boot file are not compatible. Put the card in the RPi 2 and do an update.
sudo apt-get update
I have so far only run Moode Player and Volumio. Both are the latest release, so doubt I'll need to upgrade those. Think it should be the power supply. Would a Power Supply AC ADAPTER 5V 2.5A do as suggested by a member here? Would it harm the Pi if I got a more powerful adapter?
terrible
Re: Raspberry Pi 3
Tue Mar 15, 2016 6:34 pm
WRONG!
The picture shows full-screen rainbow, which is the result of the first part of booting.
The low-voltage indication is small, top-right, after booting.
Don't know what should be causing that since I am using the latest version of moode as well as Volumio.
terrible
Re: Raspberry Pi 3
Tue Mar 15, 2016 6:37 pm
jamesh wrote:Double check the lead if you still have power problems after the upgrade. I use a 2A device no problems.
What upgrade are you talking about?
klricks
Re: Raspberry Pi 3
Tue Mar 15, 2016 7:33 pm
sudo apt-get update
You need to run the 2 commands above to update the boot code so the 3B can boot. This has nothing to do with the 2 apps you mentioned however they will be updated as well if there is a newer version(s).
If your 2A power supply is working try that first. Get the RPi booting as I am not sure the warning you see is valid without the correct boot code? You can use 2A 2.5A 5A or more it does not matter if the Amp rating is higher. Just can't be lower than you need.
FattyXP
Re: Raspberry Pi 3
Tue Mar 15, 2016 11:11 pm
The OP has BOTH indicators. I recently got an RPi3 and attempted to use the OpenELEC version included on NOOBs, this gave me the blank screen with the rainbow in the top right, so that error is not EXCLUSIVE to power supply issues (as the OpenELEC Rpi2 image on NOOBs is not compatible with the RPi3)
You cannot use an SD straight from an RPi2 in an RPi3 in most situations, you'll need to try an upgrade or fresh install. Remember to backup any data you may need first.
RaTTuS
Re: Raspberry Pi 3
Wed Mar 16, 2016 8:56 am
FattyXP wrote:The OP has BOTH indicators. I recently got an RPi3 and attempted to use the OpenELEC version included on NOOBs, this gave me the blank screen with the rainbow in the top right, so that error is not EXCLUSIVE to power supply issues (as the OpenELEC Rpi2 image on NOOBs is not compatible with the RPi3)
yes but upgrading the firmware is a must first
Covfefe
ghans
Re: Raspberry Pi 3
Wed Mar 16, 2016 9:02 am
It doesn't seem too far-fetched that the most recent
version for Volumio simply hasn't been updated to work on
the Pi3.
Wait till the Volumio authors catch up with Raspbian.
ghans
terrible
Re: Raspberry Pi 3
Wed Mar 16, 2016 12:10 pm
So, I have been trying to
sudo apt-get update
I am doing this with a fresh install of Moode 2.5 and on Raspi 2. Post which I shoved the SD card into Raspi 3 but to no avail. I still get the same large rainbow screen with a smaller one adjacent. Ater update and upgrade, do I need to reboot the SD card in Raspi 2?
do I need to do these?:
sudo apt-get dist-upgrade
sudo rpi-update
sudo reboot
RaTTuS
Re: Raspberry Pi 3
Wed Mar 16, 2016 12:28 pm
I have no idea what a moode is ? is it http://moodeaudio.org/
if so then they need to make a newer version ?
or another question are you running wheezy or Jessie ?
can you not start off with a fresh install of raspbain Jessie and add the things to that - use a new sdcard
Covfefe
Re: Raspberry Pi 3
Wed Mar 16, 2016 12:30 pm
terrible wrote:sudo rpi-update
This should only be run if it has been advised by a developer that it is needed to fix an issue you are experiencing.....
terrible
Re: Raspberry Pi 3
Wed Mar 16, 2016 12:36 pm
RaTTuS wrote:I have no idea what a moode is ? is it http://moodeaudio.org/
I have made a fresh install of Moode audio. I could install Raspbian Jessie but I have no idea what it is and whether I can install moode on it and if so whats the process. I am completely new to this as I got into it 'coz someone suggested instead of buying an expensive music server I should go for this. Raspi 2 worked fine but then I bought Raspi 3 for its wireless feature and now I am struggling.
terrible
Re: Raspberry Pi 3
Wed Mar 16, 2016 12:37 pm
If you go up in the thread I was advised to do this.
RaTTuS
Re: Raspberry Pi 3
Wed Mar 16, 2016 12:40 pm
I would contact the moode people and wait for them to update the system - they seem to be fairly active on updates
Covfefe
terrible
Re: Raspberry Pi 3
Wed Mar 16, 2016 1:05 pm
Now the small rainbow screen has disappeared but the big one stays.
DirkS
Re: Raspberry Pi 3
Wed Mar 16, 2016 1:18 pm
terrible wrote:Now the small rainbow screen has disappeared but the big one stays.
As mentioned above: the image has to be updated by the moode people to make it compatible with the Pi3B
I actually checked the image and the stuff on there is fairly recent, but pre-Pi3B.
RPF Repos are not used, so apt-get update / upgrade will not get the latest kernel firmware.
I assume rpi-update is not installed either.
terrible
Re: Raspberry Pi 3
Wed Mar 16, 2016 2:25 pm
Yes you are right. I emailed Tim and he spoke about a certain kernel not being there yet. But he proposed this moode image created by someone else. It has some Hifiberry issues though http://www.diyaudio.com/forums/pc-based ... i-208.html
I'll try this.
terrible
Re: Raspberry Pi 3
Wed Mar 16, 2016 5:27 pm
Thank you for all your help. I have finally got the Pi 3 up with a modded version of Moode Player.
