Drew7544
Wifi set up
Tue Mar 15, 2016 4:00 am
Hi all Newbie here to the world of Raspberry pi.
I have a Raspberry Pi2 with Raspian(Jessie)
for the life of me I've followed every internet tutorial about wifi set up but still no luck
on the top right there is a message that says wlan0 Not associated
I'm using a WiPi dongle from element14.
someone please help
RDS
Re: Wifi set up
Tue Mar 15, 2016 8:29 am
I think you just click on the WiFi icon, top right of your screen and it displays a list of WiFi's it can find.
Click on the one you want and enter the password.
Re: Wifi set up
Tue Mar 15, 2016 8:44 am
Drew7544 wrote:Hi all Newbie here to the world of Raspberry pi.
someone please help
Is your Wireless Adaptor compatible ?? Open a terminal type lsusb and post the output !!
https://www.raspberrypi.org/blog/anothe ... ace-update
Thinking outside the box is better than burying your head in the sand...
RDS
Re: Wifi set up
Tue Mar 15, 2016 9:08 am
He says it is from Element 14. According to the box for my WiFi dongle from Element 14, they are Official Pi suppliers
Drew7544
Re: Wifi set up
Wed Mar 16, 2016 4:59 am
yeah from element14. its called WiPi.
Drew7544
Re: Wifi set up
Wed Mar 16, 2016 5:00 am
clicked on the icon in the top right and it says no wireless interfaces found
Drew7544
Re: Wifi set up
Wed Mar 16, 2016 5:05 am
ok....I typed lsusb, and this is the text that appeared
pi@raspberrypi:~ $ lsusb
Bus 001 Device 007: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 005: ID 1c4f:0026 SiGma Micro Keyboard
Bus 001 Device 004: ID 04e8:70e1 Samsung Electronics Co., Ltd
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Drew7544
Re: Wifi set up
Thu Mar 17, 2016 10:37 am
Still no WiFi. almost ready to give up
DirkS
Re: Wifi set up
Thu Mar 17, 2016 10:47 am
Your dongle should work out of the box.
What is the output of
ifconfig
Does the red power led stay on at all times; no blinking?
Drew7544
Re: Wifi set up
Fri Mar 18, 2016 8:20 pm
DirkS wrote:Your dongle should work out of the box.
ifconfig
Hi,, yes the red power light is on all the time (no blinking)
output of ifconig is
pi@raspberrypi:~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:d4:4f:e1
inet addr:10.0.0.18 Bcast:10.0.0.255 Mask:255.255.255.0
inet6 addr: fe80::76ad:f0e4:2e8b:fd48/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4516 errors:0 dropped:0 overruns:0 frame:0
TX packets:2975 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:3592429 (3.4 MiB) TX bytes:416571 (406.8 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:212 errors:0 dropped:0 overruns:0 frame:0
TX packets:212 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:17764 (17.3 KiB) TX bytes:17764 (17.3 KiB)
wlan0 Link encap:Ethernet HWaddr 40:a5:ef:07:4a:38
inet6 addr: fe80::7ae8:347b:2753:3af4/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
DirkS
Re: Wifi set up
Sat Mar 19, 2016 1:39 am
Try
sudo iwlist wlan0 scan
to see if you can see any access points.
BTW: how is your access point set up?
Do you know the channel, security settings (WEP / WPA) and if it's hidden r not?
Drew7544
Re: Wifi set up
Thu Mar 24, 2016 3:37 am
DirkS wrote:Try
Thanks for your reply.
I found a tutorial that worked.
just played around with the setting on the command line with a few extra lines.
haitrieudo
Re: Wifi set up
Sun Mar 27, 2016 10:24 pm
How do I set for
WEP Key: 64Bit
Re: Wifi set up
Sun Mar 27, 2016 11:14 pm
haitrieudo wrote:How do I set for
WEP Key: 64Bit
Simple answer: DON'T, change your network to use WPA or WPA2.
Complex answer:
     ctrl_interface=/var/run/wpa_supplicant
     ctrl_interface_group=wheel
     network={
	     ssid="example"
	     scan_ssid=1
	     key_mgmt=NONE
	     wep_tx_keyidx=0
	     # hex keys denoted without quotes
	     wep_key0=42FEEDDEAFBABEDEAFBEEFAA55
	     # ASCII keys denoted with quotes.
	     wep_key1="FreeBSDr0cks!"
you really don't want to use WEP because you may as well set your network as open for all the security you get with WEP, it takes about five minutes to crack a WEP network.
Abhiraj Tiwari
Re: Wifi set up
Thu Mar 31, 2016 11:04 am
someone please help
I faced the same problem a few months back... i was not able to get my wifi up after searching on internet and a few posts on the forum. I used to find the network but was not able to connect to it. It said that the password was too short.
This is not the best option but if you are really determined to setup the wifi try using Ubuntu MATE. It automatically sets up your wifi no errors... and has a better GUI, although i learned the basics of linux on raspbian. You can give it a try. :)
