barbeker
how to score higher baude rate with serial RPI2RPI
Mon Mar 14, 2016 9:29 am
I'm rather new to RPI and python and I could really use your help, so thanks in advance. So my project main goal is to transmit data (a jpeg file for instance) from one RPI 2 to another one asynchronously. Currently I'm using the UART pins and a simple python program, which its main modulus are:
#initiating the serial port
   self.ser = serial.Serial(
        port='/dev/ttyUSB0',
        baudrate= int(self.baudRate),
        parity=serial.PARITY_NONE,
        stopbits=serial.STOPBITS_ONE,
        bytesize=serial.EIGHTBITS,
        rtscts=False,
        dsrdtr=False
#writing data to the port
   f=open(self.filename, 'rb')
    data=f.read()
    data_length=str(len(data)) #writing the size of the file I wish to send
    data_length1=str(len(data_length))
    size=data_length1+data_length
    self.ser.write(size) #writing the size of the file I wish to send
    for b in data:
        self.ser.write(b))
#reading data from the port
 file=open(self.filename, 'wb')
   first=int(self.ser.read(1))
   file_l=int(self.ser.read(first))  # figuring the size of the file
   data=self.ser.read(1)
   for i in range (1,file_l):
       data+=self.ser.read(1)
   file.write(data)
the thing is that no matter how high I set the baud rate, I couldn’t get a writing rate of over 380Kbps. When I didn't use the "for" loop on the transmitter moudule, It seemed that the writing was indeed faster, but then the receiver couldn't read anything. Any advices on how to reach higher rates?
thank you very much and please forgive my English
RaTTuS
Contact: Twitter YouTube
Re: how to score higher baude rate with serial RPI2RPI
Mon Mar 14, 2016 9:32 am
viewtopic.php?f=44&t=51633
though for high speed use the Ethernet
Covfefe
barbeker
Mon Mar 14, 2016 10:21 am
RaTTuS wrote:viewtopic.php?f=44&t=51633
thank you for your replay i did reat that post but the thing is i need the RPIS to stand alone without any network involved
RaTTuS
Mon Mar 14, 2016 11:02 am
you can use the Ethernet with no network - setup dhcpd so one machines acts as a server and the other as a client
or both have static ips
Covfefe
RaTTuS
Tue Mar 15, 2016 11:57 am
Covfefe
