mauripereg
how to set an ip address
Sun Mar 13, 2016 7:15 pm
hello
i'm new with raspberry.
I have installed Raspbian Jessie on my board and I need start on the boad a vncserver in order to use the board connected by ethernet with my PC using a cable.
I nees also to set a fix ip address for my board on the ethernet port.
how can I do?
PS i'm also new with Linux...
knute
Re: how to set an ip address
Mon Mar 14, 2016 3:55 am
There are two options for VNC, first is tightvncserver which will give you a virtual desktop and x11vnc which will repeat the actual desktop.
The instructions for setting up a fixed IP address can be found by running man dhcpcd.conf and looking for the static IP settings.
Rather than set a fixed IP in your Pi you can also tell your router to give the Pi the same address every time. That's what I do and then if I need to hook my Pi up to a different network it will just get a dynamic address.
TideMan
Mon Mar 14, 2016 6:34 am
Another option is remote desktop:
sudo apt-get install xrdp
and use Remote Desktop Connection from Windows Accessories.
Jessie has the multicast domain name server installed by default, so you can address your RPi as computer_name.local from Windows or anywhere else on the network, meaning you don't need to know the IP address.
DirkS
Mon Mar 14, 2016 12:03 pm
TideMan wrote:you can address your RPi as computer_name.local from Windows
I thought you needed Bonjour service installed on Windows to do that...
Mon Mar 14, 2016 3:18 pm
You do. It's relatively painless to install avahi-daemon to provide the Bonjour service.
This is a doctor free zone.
Candyjet
Mon Mar 14, 2016 4:35 pm
I have Bonjour running on my Windows 10, and my Jessie Pi 2 tells me that it looks like xrdp is already running, but I can't connect with RDC.
My Pi appears on my home network as xxxx. Do I type in xxxx.local as the name of the remote computer?
CJ
TideMan
Mon Mar 14, 2016 7:24 pm
Candyjet wrote: My Pi appears on my home network as xxxx. Do I type in xxxx.local as the name of the remote computer?
Yes.
