hilman
When should I 'rpi-update' the Raspbian?
Sun Mar 13, 2016 11:10 am
I always don't get this right. After I have downloaded and installed the latest Raspbian on my Pi 2, I will first 'apt-get update' it and then 'apt-get upgrade' it. And then, every time I 'rpi-update' it, there will always be some sort of problems. Is it means I should no 'rpi-update' the Raspbian? If so, when should I 'rpi-update' it?
PeterO
Re: When should I 'rpi-update' the Raspbian?
Sun Mar 13, 2016 11:17 am
hilman wrote:when should I 'rpi-update' it?
It's best to only do it when told to by someone who is closely involved with the kernel & firmware development. When new features are being developed there is a risk that your PI won't boot afterwards :o
PeterO
Sun Mar 13, 2016 11:29 am
hilman wrote:I always don't get this right. After I have downloaded and installed the latest Raspbian on my Pi 2, I will first 'apt-get update' it and then 'apt-get upgrade' it. And then, every time I 'rpi-update' it, there will always be some sort of problems. Is it means I should no 'rpi-update' the Raspbian? If so, when should I 'rpi-update' it?
Personally I only ever undertake
sudo apt-get update
sudo apt-get dist-upgrade
As PeterO stated rpi-update is only used for resolving a specific issue or you know the pitfalls of doing so ;)
RPi 4B 4GB (SSD Boot)..
Sun Mar 13, 2016 1:08 pm
PeterO
+1
The latest BRANCH=next rpi-update stopped my RPF touchscreen working (admittedly that's even more leading edge than plain rpi-update).
hilman
Sun Mar 13, 2016 1:09 pm
PeterO
So, I should just
apt-get update
apt-get upgrade
hilman
Sun Mar 13, 2016 1:10 pm
sudo apt-get update
What is the difference between 'apt-get dist-upgrade' and 'apt-get upgrade'? Is it one better than the other?
kusti8
Sun Mar 13, 2016 1:12 pm
There are 10 types of people: those who understand binary and those who don't.
Sun Mar 13, 2016 1:22 pm
sudo apt-get update
http://linux.die.net/man/8/apt-get
Nickcn
Sun Mar 13, 2016 1:32 pm
deleted
Sun Mar 13, 2016 2:37 pm
In a nutshell...
dist-upgrade is more likely to break stuff badly than upgrade. upgrade ensures that your system remains complete
dist-upgrade is more likely to fix issues with conflicting package versions, if you are comfortable with taking the road roller approach (i.e. you don't have a mission critical production software running on the box)
Poppycock and Balderdash, I have never had dist-upgrade issues, only if you install non-Repository packages could it be an issue but that applies to upgrade as well...
RichInTheUSA
Wed Aug 29, 2018 6:27 pm
Whoops... what if I had issued the rpi-update command, and now want to go back to the stable kernel and firmware? Is there a way to reverse the impact of the rpi-update command? Newbie error, sorry.
PeterO
Wed Aug 29, 2018 6:57 pm
You can go back to any commit id with rpi-update. Or you can re-install the raspberrypi-kernel package.
sudo rpi-update 911147a3276beee09afc4237e1b7b964e61fb88a
would get you back to the latest stable kernel.
Re-installing raspberrypi-kernel
sudo apt install --reinstall raspberrypi-kernel
is the safer option.
RichInTheUSA
Thu Aug 30, 2018 12:08 am
Thanks man!!!
Return to “Beginners”
