nivm200
time.sleep() stops code
Sat Mar 05, 2016 6:42 pm
I want to run a loop with a delay every time the code in it is called, but whenever I use time.sleep() I can only run one loop and I need more than 1 loop to run at certain time... how can I associate the the time for the loop only and not the rest of the code?
gordon77
Re: time.sleep() stops code
Sat Mar 05, 2016 6:59 pm
Post you code on here then we can see if we can help.
Laurens-wuyts
Sat Mar 05, 2016 7:00 pm
For doing that, you should use a timer or threads. ;)
Laurens
nivm200
Sun Mar 06, 2016 8:01 am
any example code for threads/timers? I will add me code once il get home.
Laurens-wuyts
Sun Mar 06, 2016 8:23 am
Here are some example scripts using threads. :)
You need to make a function for every separate loop you want, and start it as a thread.
Laurens
nivm200
Sun Mar 06, 2016 3:25 pm
thank you!
SSL
Sun Mar 06, 2016 8:21 pm
Even though this shouldn't be a problem, that I can see, try putting your variables into the loop if they're not already. I had a simular situation where the loop would only run once then stop, but if I put the variables I used in the loop it worked. If not, then I'm out of idea's. Good luck, though!
