lynchd
Pi doesn't like my monitor
Fri Mar 04, 2016 2:36 am
Just got my Pi 2 up and running but it will not work with the old VGA monitors I have. It works fine with my TV which I can connect with an HDMI cable.
The monitors are being connected with an adapter. http://www.amazon.com/gp/product/B007PL ... ge_o03_s00
One monitor is a Dell and the other is a MAG.
Can I change some setting so that the Pi will work with my old monitors?
If I change that setting, will the Pi still work with the TV?
Thanks for your help.
texy
Re: Pi doesn't like my monitor
Fri Mar 04, 2016 2:26 pm
According to your previous post your Pi isn't booting :oops:
viewtopic.php?f=91&t=138412&p=918625#p918625
It's always a nice thing to let people know that issues are fixed.
Texy
lynchd
Sat Mar 05, 2016 1:38 am
It wasn't that the Pi wasn't booting, the problem was that I could only see the desktop for a few seconds before the screen went to black. I worked around that by plugging into a newer TV instead of the older monitors I was trying to use. They still are not working but I may have made contact with someone who has a solution to that problem. If I do solve my problem I will post the solution that I work out- if I can. At least now by using the Tv I can make whatever change to the settings that will let me have the Pi work with the old monitor.
DirkS
Sat Mar 05, 2016 1:08 pm
lynchd wrote:Can I change some setting so that the Pi will work with my old monitors?.
You may have to set a specific mode. See viewtopic.php?f=28&t=5851&p=77547#p77547
Basically you rip out all the hdmi settings from /boot/config.txt and then run diagnostics to determine the correct setting
You may have to change settings (or additional ones) to get it to work again on your tv, but I would not worry about that for now.
(there are ways of setting parameters for specific screens).
