Renaming my Pi
Tue Aug 07, 2012 11:52 am
I have recently received my second pi in the mail and am not sure how to rename them so that they don't clash being on the same network.
I thought it was as simple as editing /etc/hostname in nano
This did largely work but I have noticed a few issues
1) When I close the desktop I notice error messages e.g. bad display name "serverpi:0" in "remove" command
2) When trying to download a package i get "-bash: syntax error near unexpected token ';;'"
3) My router shows both PIs as still being "RASPBERRYPI"
How do I change the name of the PI?
Is it necessary when using multiple PIs on a network?
Re: Renaming my Pi
Tue Aug 07, 2012 12:33 pm
edit /etc/hosts and
Re: Renaming my Pi
Tue Aug 07, 2012 12:42 pm
EDIT: RaTTus was faster ;)
Hello raven_squire,
speaking at least from a Debian point of view, changing the hostname is as simple as possible:
root@server:# hostname ServerXYZ
Concerning network communication you might also want to look into /etc/hosts, where machine names are matched to IP addresses. Since you only edited the /etc/hostname file the /etc/hosts file will surely still contain wrong information.
I would consider it necessary to change the name if you want to run both Pis in one network. Of course, network traffic is based on IP addresses and your network hardware does not care about names, but as soon as name resolution comes into play you will get into trouble.
"If people read the FAQs the Qs wouldn't be A F, would they?"
Re: Renaming my Pi
Tue Aug 07, 2012 1:21 pm
Thankyou gentlemen!!!
This worked fine. My router apparently has difficulties with name resolution as I saw it loose other names on DHCP devices. So this made the perfect opportunity to populate /etc/hosts
Thanks again!!
Thankyou gentelmen
Who is online
Users browsing this forum: darkbibble, WilliamOL and 34 guests
