himani18
Wanted to run raspberry program endlessly...
Fri Feb 19, 2016 5:07 pm
I am working on one project..
I want this project should run endlessly...
Suppose if there is not power supply or hdmi o/p then also i want my code to run...
IF there is power failure...even though it should work..
I dont want to type python example.py for executing it everytime..
any suggestions???
elatllat
Re: Wanted to run raspberry program endlessly...
Fri Feb 19, 2016 7:07 pm
make a service
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
asandford
Fri Feb 19, 2016 7:17 pm
himani18 wrote: Suppose if there is not power supply or hdmi o/p then also i want my code to run...
You don't need hdmi for a program to run; power, on the other hand, is pretty much a prerequisite...
