havard
no touch responsive after update
Fri Feb 19, 2016 12:09 pm
Hi guys
i have a
LCD Type TFT
LCD Interface SPI
Touch Screen Type Resistive
Touch Screen Controller XPT2046
Colors 65536
Backlight LED
Resolution 480*320 (Pixel)
touch screen working fine with the original img by manufacturer gave it to me
but after update my raspberry pi with these commands
$ sudo apt-mark hold raspberrypi-bootloader
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo apt-get install rpi-update
$ sudo rpi-update
$ sudo reboot
after boot my LCD working but my touch screen wont work !
can you help me plz
DirkS
Re: no touch responsive after update
Sat Feb 20, 2016 12:31 am
Well, you stopped a new kernel + firmware from installing by 'holding' raspberrypi-bootloader.
Then you installed a new kernel + firmware by using rpi-update...
rpi-update creates a backup of the contents of /boot (that's the FAT partition on your SD card) in /boot.bak.
Basically you need to copy the contents /boot.bak back to its origin.
AFAIK it should be possible to do this on a running system.
Make a backup of your SD card first. You could make an image with Win32DiskImager for example.
When you're logged in to your Pi you can copy the files with
sudo cp -rv /boot.bak/* /boot/
Reboot and hope for the best.
And don't use rpi-update again
