I wrote 2016-02-09-raspbian-jessie image to SD card. it boots up. I use browser to watch youtube. but there is no sound.
anybody else has this issue?
thanks
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Re: 2016-02-09-raspbian-jessie no sound
HDMI or analog? Have you selected the right output?
I use HDMI. I thought voice set to HDMI by default. because my old raspbian OS did not set anything.
How to set voice to HDMI?
thank you.
thank you.
I don't know what the default is. I'd guess HDMI as well.
Just in case, right click the speaker in the taskbar, or use raspi-config.
Yes default is HDMi, but you have not stated what you are using for a Screen ?Lxw2015 wrote:I use HDMI. I thought voice set to HDMI by default. because my old raspbian OS did not set anything.
thank you.
The information is out there....you just have to let it in.
I found answer on web. the default is set to auto. some how jessie doesn't detect HDMI, so set it to hdmi_drive=2 in /boot/config.txt
