Read Several GPIOS (Inputs)
Posted: Mon Feb 08, 2016 7:01 pm
by chrisoma
Hello
I'm looking for help about how to read the level of 9 inputs with a single instruction... (using Python)
Is it possible..?
Actually the application that I'm trying to resolve is a Legacy Printer Capture (read parallel output with Digital I/O's), but the read frequency its too low with 8 or nine instructions. (about 2K reads per second and I need to get over 20K)
Is there someone that already go thru this scenario...?
Re: Read Several GPIOS (Inputs)
Posted: Mon Feb 08, 2016 7:20 pm
by joan
It's one thing to read the GPIO, but how are you going to make sense of the bits? How do you know when a new "sample" is ready to be read?
Posted: Mon Feb 08, 2016 8:30 pm
by liudr
Use Arduino instead. Easy to get 9 pins read in two statements, down to microsecond delay between the first 8 and the last one.
Posted: Mon Feb 08, 2016 8:37 pm
by joan
liudr wrote:Use Arduino instead. Easy to get 9 pins read in two statements, down to microsecond delay between the first 8 and the last one.
You can read 32 pins on the Pi in 40 nanoseconds. The problem will be how to make sense of the data.
Posted: Mon Feb 08, 2016 9:30 pm
by chrisoma
8 pins for the data, and the last one is the Strobe signal (STO), (this legacy device don't support handshake protocol).
Data bits only receive ASCII characters as info. A simple int to cad convertion do the job to translate the data.
These are the instructions I'm using , but takes to long.
D0= GPIO.input(insput1)
D1= GPIO.input(insput2)
D2= GPIO.input(insput3)
D3= GPIO.input(insput4)
D4= GPIO.input(insput5)
D5= GPIO.input(insput6)
D6= GPIO.input(insput7)
D7= GPIO.input(insput8)
cad = D0+(D1*2)+(D2*4)+(D3*8)+(D4*16)+(D5*32)+(D6*64)+(D7*128)
Posted: Mon Feb 08, 2016 11:52 pm
by joan
You are probably being too ambitious for Python. Have you considered C instead?
The following Python manages about 18k on a Pi2. I'd expect less than half that on other Pi models.
#!/usr/bin/env python
import time
import struct
import pigpio # http://abyz.co.uk/rpi/pigpio/python.html
#     0  1  2  3   4   5   6   7
BITS=[4, 7, 8, 9, 10, 11, 14, 15]
STROBE=17
COUNT=40000
pi = pigpio.pi() # Connect to Pi.
if not pi.connected:
   exit(0)
h = pi.notify_open()
pi.notify_begin(h, 1<<STROBE)
try:
   f = open("/dev/pigpio"+ str(h), "rb")
   f_out = open("log", "w")
   n = 0
   start = time.time()
   while True:
      chunk = f.read(12)
      if len(chunk) == 12:
         seqno, flags, tick, level = struct.unpack('HHII', chunk)
         if level & (1<<STROBE): # Strobe bit set?
            cad = 0
            if level & BITS[0]:
               cad |= 1
            if level & BITS[1]:
               cad |= 2
            if level & BITS[2]:
               cad |= 4
            if level & BITS[3]:
               cad |= 8
            if level & BITS[4]:
               cad |= 16
            if level & BITS[5]:
               cad |= 32
            if level & BITS[6]:
               cad |= 64
            if level & BITS[7]:
               cad |= 128
            f_out.write(str(cad)+"\n")
            n += 1
            if n >= COUNT:
               break
      else:
         break
   stop = time.time()
   print(COUNT, stop-start)
   f.close()
   f_out.close()
except IOError:
   pass
pi.notify_close(h)
pi.stop() # Disconnect from Pi.
Posted: Tue Feb 09, 2016 6:13 am
by rpdom
I'd probably do it in C. It would handle the speed easily and be able to read GPIO 0-31 in one go. Then you just need to shuffle the bits around into the right order.
Since someone mentioned something about supporting a legacy parallel printer app on here a while back, I've been toying with the idea of building an interface board and code that will support it,
Posted: Tue Feb 09, 2016 6:16 pm
by liudr
With an operating system such as raspbian? Is it sustainable?
