TheGuyUk
Raspbian 1.5.0 to 1.6.0
Mon Feb 08, 2016 1:00 pm
Hello I am new to Pi computers and Raspbian I download version 1.5.0 and installed it on my RPi Z today I noticed Noobs is a newer version 1.6.0 .
So what is different, do I need to download and reinstall Noobs or is there a easier way to upgrade?
I have read about and run Sudo rpi-update but then I saw reference to Sudo get-app update and Sudo get-app upgrade ( last two I have not run ).
Whats new in version Raspbian 1.6.0?
Any advice or help appreciated.
Cheers
ShiftPlusOne
Re: Raspbian 1.5.0 to 1.6.0
Mon Feb 08, 2016 1:08 pm
http://downloads.raspberrypi.org/raspbi ... _notes.txt
Proper blog post coming tomorrow.
Windows 10 IoT has been added to NOOBS.
On the raspbian side, you can just run 'sudo apt-get update && sudo apt-get dist-upgrade' to be fairly up to date.
There's an experimental gl driver option, but I don't recommend using that until the blog post is up.
liudr
Mon Feb 08, 2016 4:26 pm
Nice updates to the distro. Will jessie ever include python 3.5 and pyserial? I had to learn how to build and install.
Arduino data loggers, user interface, printed circuit board designer since 2009, RPI 3B 2B 2B Zero Jessie, assembly/C/C++/java/python programmer since the 80's
DirkS
Mon Feb 08, 2016 4:40 pm
liudr wrote:Nice updates to the distro. Will jessie ever include python 3.5
No, it follows Debian Jessie and they will not put in a new version (see e.g. https://release.debian.org/jessie/freeze_policy.html)
pyserial should be easily updated using 'pip'
beta-tester
Mon Feb 08, 2016 4:49 pm
strange, i am pretty sure i was looking to the NOOBS/Raspbian Downloads one or two days ago, and there wasn’t those downloads available, but the date tells it is from 2016-02-03... :?
thank you for pointing me to that new versions ;)
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
ShiftPlusOne
Mon Feb 08, 2016 5:00 pm
beta-tester wrote:strange, i am pretty sure i was looking to the NOOBS/Raspbian Downloads one or two days ago, and there wasn’t those downloads available, but the date tells it is from 2016-02-03... :?
The 'release date' is the date the image was created, rather than published, due to ahm.... reasons.
mattmiller
Mon Feb 08, 2016 7:58 pm
Does it include support for PiZero USB OTG without needing custom kernels?
Matthew
ShiftPlusOne
Mon Feb 08, 2016 8:07 pm
The necessary kernel module is not in the 4.1 kernel, so you'll still need to rpi-update to 4.4 for that.
TheGuyUk
Mon Feb 08, 2016 8:17 pm
ShiftPlusOne wrote:http://downloads.raspberrypi.org/raspbi ... _notes.txt
Thank you ☺
Mon Feb 08, 2016 8:37 pm
TheGuyUk wrote::)
Cheers
Version 15.0 & 1.6.0 are NOOBS Version and NOT Raspbian Version :?
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
NickT
Tue Feb 09, 2016 1:49 pm
This appears to work successfully with one proviso:
If, like me, you find that upgrading Wolfram from its repository takes forever, then you are better off prohibiting the upgrade or removing Wolfram all together. I appreciate that it's a useful educational tool but I and many others find the upgrade process unworkable. The Foundation need to address this problem of slow downloading at some time.
