RDK
How to detect corrupted file system
Thu Feb 04, 2016 1:32 pm
Is there a simple command which will tell me if any part of the SD's file system or my USB stick's (auto-mounted) has been corrupted by a "non-graceful" shutdown?
With Wheezy and attached to a monitor I could usually see the error or warning messages on the screen, but not so from PUTTY.
With Jessie the messages go by so fast that I can not read them and the final screen does not show any thing about the file system.
So, I'm looking for a command line command which I can use on either system to detail the state of the Pi's file system.
Thanks for you assistance.....RDK
jahboater
Re: How to detect corrupted file system
Thu Feb 04, 2016 4:20 pm
You probably want fsck (man fsck for details).
For boot messages try dmesg
"We are in the beginning of a mass extinction, and all you can talk
about is money and fairy tales of eternal economic growth."
- Greta Thunberg
RDK
Thu Feb 04, 2016 5:59 pm
OK, I will read up on fsck, but as I recall it is only good for Linux file systems. I'm sure my USB memory stick is FAT or FAT32.
Thanks....RDK
Thu Feb 04, 2016 6:03 pm
There are fsck extensions for most file systems. fsck on a vfat file system will call fsck.vfat aka dosfsck from the dosfstools package.
RDK
Sat Feb 13, 2016 12:39 am
I guess I need to be a little more specific. First off I'm a novice when it comes to Linux. My Raspberry Pi's (a B+ and a V2) are running headless, so I do not get to see the information displayed on the console during boot-up. My Pi's are running Wheezy with a standard SD card (8 GB) and a 16 GB USB memory stick formatted FAT (or maybe FAT32?).
What I'm looking for is a command or a set of commands which will tell me if any part of the file system has been corrupted by a "non-graceful" shutdown or for any other reason. After that I think I have already researched the techniques to repair the corrupted elements.
Thanks....RDK
beta-tester
Sat Feb 13, 2016 5:43 am
RDK wrote:I guess I need to be a little more specific. First off I'm a novice when it comes to Linux. My Raspberry Pi's (a B+ and a V2) are running headless, so I do not get to see the information displayed on the console during boot-up. My Pi's are running Wheezy with a standard SD card (8 GB) and a 16 GB USB memory stick formatted FAT (or maybe FAT32?).
Thanks....RDK
as jahboater told you...
jahboater wrote:You probably want fsck (man fsck for details).
use dmesg to see the boot message
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
