JohnHowley
Epson Print Driver Compilation Issues
Mon Feb 01, 2016 4:11 pm
Hi All,
I have a problem installing the Epson escpr drivers. I'm using Raspian 4.1.13 #826 and I'm on a Raspberry Pi 1 B model.
The autoinstall packages only cover i386, i486, x86 and amd64 and not all of those in .deb format. So I've downloaded the source and tried compiling them.
I've had a few issues along the way with missing dependencies but have managed to get round them all with a few web searches.
Now I'm stuck though - I get lots of 'undefined references' and have no clue where to start. I've seen a few posts talking about providing more detail to the Make file, but I just can't work out what to do so any help would be greatly appreciated.
The job I'm trying to complete is to make my Epson XP-620 available through a CUPS print server on my Pi.
Here's the error I'm getting:
[email protected]:~/epson-inkjet-printer-escpr-1.6.3 $ make
make  all-recursive
make[1]: Entering directory '/home/pi/epson-inkjet-printer-escpr-1.6.3'
Making all in lib
make[2]: Entering directory '/home/pi/epson-inkjet-printer-escpr-1.6.3/lib'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/home/pi/epson-inkjet-printer-escpr-1.6.3/lib'
Making all in ppd
make[2]: Entering directory '/home/pi/epson-inkjet-printer-escpr-1.6.3/ppd'
make[2]: Leaving directory '/home/pi/epson-inkjet-printer-escpr-1.6.3/ppd'
Making all in src
make[2]: Entering directory '/home/pi/epson-inkjet-printer-escpr-1.6.3/src'
/bin/bash ../libtool  --tag=CC   --mode=link gcc -Wall -DCUPS_FILTER_NAME=\"epson-escpr\" -DCUPS_FILTER_PATH=\"/usr/lib/cups/filter\"  -g -O2 -lpthread  -o epson-escpr-wrapper epson_escpr_wrapper-wrapper.o
libtool: link: gcc -Wall -DCUPS_FILTER_NAME=\"epson-escpr\" -DCUPS_FILTER_PATH=\"/usr/lib/cups/filter\" -g -O2 -o epson-escpr-wrapper epson_escpr_wrapper-wrapper.o  -lpthread
epson_escpr_wrapper-wrapper.o: In function `get_default_choice':
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:588: undefined reference to `ppdFindOption'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:592: undefined reference to `ppdFindChoice'
epson_escpr_wrapper-wrapper.o: In function `get_option_for_ppd':
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:376: undefined reference to `cupsGetPPD'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:377: undefined reference to `ppdOpenFile'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:505: undefined reference to `ppdClose'
epson_escpr_wrapper-wrapper.o: In function `main':
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:167: undefined reference to `cupsRasterOpen'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:189: undefined reference to `cupsRasterReadHeader'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:336: undefined reference to `cupsRasterReadPixels'
epson_escpr_wrapper-wrapper.o: In function `get_option_for_arg':
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:525: undefined reference to `cupsParseOptions'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:529: undefined reference to `cupsGetOption'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:361: undefined reference to `cupsRasterClose'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:547: undefined reference to `cupsGetOption'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:551: undefined reference to `cupsGetOption'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:561: undefined reference to `cupsGetOption'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:565: undefined reference to `cupsGetOption'
/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:569: undefined reference to `cupsGetOption'
epson_escpr_wrapper-wrapper.o:/home/pi/epson-inkjet-printer-escpr-1.6.3/src/wrapper.c:573: more undefined references to `cupsGetOption' follow
collect2: error: ld returned 1 exit status
Makefile:419: recipe for target 'epson-escpr-wrapper' failed
make[2]: *** [epson-escpr-wrapper] Error 1
make[2]: Leaving directory '/home/pi/epson-inkjet-printer-escpr-1.6.3/src'
Makefile:431: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/pi/epson-inkjet-printer-escpr-1.6.3'
Makefile:357: recipe for target 'all' failed
make: *** [all] Error 2
Re: Epson Print Driver Compilation Issues
Mon Feb 01, 2016 6:18 pm
JohnHowley wrote:The job I'm trying to complete is to make my Epson XP-620 available through a CUPS print server on my Pi.
Does CUPS recognise the Printer is attached ??
If so it should give an option to configure using a PPD file, have you tried that ??
Last edited by fruitoftheloom on Tue Mar 29, 2016 5:46 pm, edited 1 time in total.
Retired disgracefully.....
vuckovic
Tue Mar 29, 2016 5:33 pm
Hi , I have the same problem with L850 and L1800 . Any chance you've cracked it ? Any guidance would be much appreciated. Ty
Tue Mar 29, 2016 5:51 pm
vuckovic wrote:Hi , I have the same problem with L850 and L1800 . Any chance you've cracked it ? Any guidance would be much appreciated. Ty
AFAIA the Epson Driver Source is for x86-32 / x86-64 architecture, the RPi is ARM Architecture !
Gutenprint support many Epson Printers under Linux, even the L1800: http://gimp-print.sourceforge.net
Does CUPS actually recognise your Printers ?????????
scruss
Tue Mar 29, 2016 7:10 pm
My Raspberry Pis find my networked Epson printer no bother. I had to install cups and system-config-printer for this to work. Didn't have to build anything.
gregeric
Thu Mar 31, 2016 8:36 pm
Been too busy to reply before now but if OP JohnHowley's still around, your compilation issues aren't related to "x86 driver source code".
Compilation errors should be fixed with:
./configure --prefix=/usr --with-cupsfilterdir=/usr/lib/cups/filter --with-cupsppddir=usr/share/ppd
mcfl33go
Thu Aug 04, 2016 5:11 pm
I'm trying to compile to get the Epson ET-2550 to work. The proper configure syntax helped a great deal, but I'm getting these messages now when I try to run the make command:
CDPATH="${ZSH_VERSION+.}:" && cd . && aclocal-1.14 -I m4
cd . && automake-1.14 --gnu
lib/Makefile.am:47: error: Libtool library used but 'LIBTOOL' is undefined
lib/Makefile.am:47: The usual way to define 'LIBTOOL' is to add 'LT_INIT'
lib/Makefile.am:47: to 'configure.ac' and run 'aclocal' and 'autoconf' again.
lib/Makefile.am:47: If 'LT_INIT' is in 'configure.ac', make sure
lib/Makefile.am:47: its definition is in aclocal's search path.
Makefile:276: recipe for target 'Makefile.in' failed
make: *** [Makefile.in] Error 1
Any further suggestions on this?
Thanks!
scruss
Fri Aug 05, 2016 12:45 pm
That configure line should probably have --with-cupsppddir=/usr/share/ppd.
The error suggests running aclocal and autoconf before calling ./configure.
humphreybas
Sat Oct 08, 2016 6:27 pm
This other thread that I started regarding compiling the Epson driver might be helpful as well:
viewtopic.php?f=66&t=145425
