How to instal 2nd OS without removing Raspbian on 1sdcard
Posted: Sat Jan 30, 2016 3:32 am
by Mathan
I installed raspbian through NOOBS. Now I need to install OPEN ELEC in same sd card in different partition without affecting any changes to my raspbian.
I tried via NOOBS but it showing Raspbian needs to reinstall. Is there any way to install OPEN ELEC in same sd card without removing raspbian
Re: How to instal 2nd OS without removing Raspbian on 1sdcar
Posted: Sat Jan 30, 2016 3:47 pm
by Navyscourge
You will have to re-arrange the partitions to create space, then copy in the files - this is not something that NOOBS can do.
Can you create a second card? You would have to shut down Raspbian to start OpenElec anyway. Swapping a card takes moments.
Posted: Sat Jan 30, 2016 7:39 pm
by DougieLawson
Mathan wrote:I installed raspbian through NOOBS. Now I need to install OPEN ELEC in same sd card in different partition without affecting any changes to my raspbian.
That's not possible with NOOBS. NOOBS is a pick your OS on the first boot and it's all set in stone. You can't come along later and add other OSes without trashing the contents of the SDCard.
Posted: Sun Jan 31, 2016 5:50 pm
by Mathan
I made a partition of ext 4 1 gb using gparted from puppy linux. After this i dont know what to do??
Posted: Sun Jan 31, 2016 6:01 pm
by DirkS
Mathan wrote:I made a partition of ext 4 1 gb using gparted from puppy linux. After this i dont know what to do??
If you need this much hand holding then I think it's not wise to even attempt it...
Why don't you install Kodi on top of Raspbian? That way you don't even have to reboot to switch between desktop and Kodi.
Posted: Mon Feb 01, 2016 4:05 pm
by Mathan
Is kodi another OS??
Is it able to support hardware gpu for playing video
Posted: Mon Feb 01, 2016 4:32 pm
by fruitoftheloom
Mathan wrote:Is kodi another OS??
KODI is Multimedia Software
http://kodi.tv
KODI has omxPlayer which is hardware accelerated ..
...omxPlayer is also included by default in Raspbian
http://www.raspberry-projects.com/pi/so ... /omxplayer
Posted: Mon Feb 01, 2016 5:49 pm
by r3d4
Some thing like changing "root=/dev/ partition-you-made " in cmdline.txt should work afaik.
Posted: Mon Feb 01, 2016 7:14 pm
by DirkS
r3d4 wrote:Mathan wrote:I made a partition of ext 4 1 gb using gparted from puppy linux. After this i dont know what to do??
Yes, but you may encounter problems if the two OSs use different kernels.
So you may also have to add / change a 'kernel=' line in config.txt to make it work.
And editing these files from Openelec is also a pain, because 'boot' is not mounted by default.
There may be other hurdles...
Posted: Mon Feb 01, 2016 8:13 pm
by kusti8
It would be way to hard as DirkS says. To make it work properly you would need to either shuffle around the partitions to include NOOBS (very hard) or append a boot partition and root partition to the end, copy the files, and then set the special file for the boot up partition which would still be more trouble than its worth to either install Kodi on top or get a new SD card.
