Candyjet
Use iPhone sound to trigger Pi
Fri Jan 29, 2016 9:18 pm
I want to use the headphone output of an iPhone as a trigger to be recognised by the Pi, (which will then carry out a defined action), i.e., similar to a button push, but using the sound output of the phone, instead of a physical button.
I have a few questions.
Is the sound from an iPhone likely to be loud enough to be recognised by the Pi? If so, which pins should I be using?
If not, would one of the Audio cards, eg Wolfson, do the trick? I can see that they are capable of recording sound, but I don't want that, I want to use the sound input as a trigger.
CJ
forklift
Re: Use iPhone sound to trigger Pi
Sat Jan 30, 2016 5:54 am
you could always use something like a PAC-Audio LOC module to trigger 12v on to then power the Pi, but then that would be a decent delay as the pi would then need to boot up and if enough signal were lost then so would go the power
Candyjet
Sat Jan 30, 2016 1:38 pm
Thanks forklift, but that's not quite what I'm after. I want to use a series of sound outputs, separated by silence, to produce a corresponding series of outputs from the Pi. Would a small amplifier module, if such a thing exists, do the trick?
ghans
Sat Jan 30, 2016 7:17 pm
Do you want to use air or a sound cable as medium ?
ghans
jdb
Sat Jan 30, 2016 7:24 pm
DTMF
Multimon
Plug the iPhone headphone output into a USB sound card connected to the Pi to receive the audio generated on the iPhone.
DTMF is the noise you hear when you press numbers on a telephone keypad - mobile or landline.
Rockets are loud.
https://astro-pi.org
Candyjet
Sat Jan 30, 2016 8:11 pm
Thanks jdb.
I was planning on using a sound from the left channel of the iPhone headphones to trigger one Pi action, and from the right side to trigger another using the GPIO.
Is this possible, assuming I have enough brain cells?
ghans
Sat Jan 30, 2016 8:55 pm
Do you have any programming experience , especially for the
iPhone ?
ghans
Candyjet
Sat Jan 30, 2016 10:17 pm
I've got the sounds from the iphone all sorted, thanks.
Have also got individual parts of Python written, it just needs gathering into a whole single entity, so I'm happy with the programming aspect, just this last bit of hardware needs putting in place.
ghans
Sun Jan 31, 2016 10:35 am
Sounds good.
You will need an USB sound card.
ghans
Candyjet
Sun Jan 31, 2016 11:10 am
Thanks. And to be sure, it will allow an in audio signal to be used to trigger a GPIO output?
ghans
Sun Jan 31, 2016 11:16 am
Well , you have to program it that way.
You need to analyze the audio on the Pi and invent a
protocol for GPIO control commands. A softmodem
might be part of the solution.
ghans
