macaddict
How can I install VMac for emulate Mac OS 7.5.5 on Raspberry
Fri Aug 03, 2012 1:32 pm
I am new on Raspberry Pi and I am using Debian.
I am using a Mac OS X since I was 8 years old so I love Mac software.
So I have thought about how I could install Mac OS on my Raspberry Pi.
And I remember that there is a Mac OS 7 emulator for Windows, Mac OS X, Linux, Android, iPhone OS available here : http://www.vmac.org and here : http://minivmac.sourceforge.net
This emulator works on ARM platform (android,iPhone OS) and on Linux so I think it is possible to use it on Raspberrypi but I don't know how can I install it.
Help me please !!!
ryanteck
Re: How can I install VMac for emulate Mac OS 7.5.5 on Raspb
Sat Aug 04, 2012 11:06 am
No one by the looks of it has actually ported it to Linux (Arm) , the Android and iOS versions are different.
I think it would have to be ported to arm linux itself and I don't know how recompile it (The source code looks different to me compared to normal applications :S )
Hope this helps :)
tfurrows
Thu Sep 06, 2012 5:46 pm
Minivmac 3.3.2 Alpha works well on the Raspberry Pi running Raspbian. You can download a pre-compiled ARM binary from this link:
http://minivmac.sourceforge.net/doc-3.3/download.html
You will need a vMac.ROM file (with that exact file name) which contains a Mac Plus rom. If you intend to do this legally, you technically need to own a Mac Plus, but that's another matter entirely.
I recommend reading up on this page for everything else you'll need:
http://minivmac.sourceforge.net/doc/start.html
One final note: sound appears to be buggy on the Pi for now. You can disable it with the "-alsadev noexist" option on the command line when starting MinivMac, or you can compile your own binary with sound turned off (plus, if you compile your own, you can set a custom resolution for MinivMac that will do real fullscreen, and a few other things)
Have fun, I know I am!
GiantPlaidSquirrel
Mon Jul 29, 2013 6:23 pm
HELP, I CANT UN TGZ THE FILE!!!!!!
dspolleke
Mon Jul 29, 2013 6:38 pm
Thanks for that constructive post.
a .tgz file is actually an .tar archive file that has been gzipped.
although you have elaborately described your problem and posted any error messages you encounter i am not able to think of a fix for your problem other than
unzip and extract the file using the following command:
tar -zxvf filename.tgz
Please read: http://www.biblegateway.com/passage/?search=Matthew+7%3A7&version=NIV
Use loads of sunscreen, use the search, be elaborate in questions, paste commands and error messages, and remember google is your friend!
GiantPlaidSquirrel
Mon Jul 29, 2013 8:40 pm
ive tried gzip command the tar command and even xarchiver none work. i cant even unzip zip files!
Joe Schmoe
Mon Jul 29, 2013 9:34 pm
Well, I'm not surprised.
No one has ever heard of giant plaid squirrel unzipping (or un-tarring) a file.
In fact, I think I can say authoritatively, that such has never happened.
GiantPlaidSquirrel
Tue Jul 30, 2013 3:35 pm
ha ha very funny im saying that i get a child error from the tar command stated above, child error code 1 and an unexpected end of file. which is making me think its corrupt i will post the exact error in a moment
PR77
Tue Mar 24, 2015 9:06 pm
Hi All,
Seems a bit of time has gone by on this topic without any updates. I would be interested to know if anyone has managed to get mini vMac running on the Pi natively. I.e., not hosted.
Return to “Beginners”
