windell747
setting up i2c on raspberry pi B+
Wed Jan 13, 2016 2:13 am
I followed the instructions here
https://www.youtube.com/watch?v=FloRfIeuEoE
and when I run
sudo i2cdetect -y 0
I get
Error: Could not open file '/dev/i2c-0' or 'dev.i2c/0': No such file or directory
I get the same thing when I run
sudo i2cdetect -y 1
I'm not sure what I could be doing wrong. Any hints?
windell747
Re: setting up i2c on raspberry pi B+
Fri Jan 15, 2016 2:45 am
I ran through all the steps on that page including the double-check step and i2cdetect still doesn't work. Is there anything else that I can do to troubleshoot?
W. H. Heydt
Fri Jan 15, 2016 3:06 am
Did you go into raspi-config and enable I2C? Under Jessie, you can use the graphical wrapper to do so.
windell747
Fri Jan 15, 2016 3:44 am
Yup have done all those steps. I even reinstalled the os to try it again.
joan
Fri Jan 15, 2016 11:46 am
Could you give the result of the following commands?
uname -a
cat /etc/os-release
grep i2c /boot/config.txt
grep i2c /etc/modules
windell747
Fri Jan 15, 2016 6:53 pm
Thanks fellow RPiers. Here you go!
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.18.7+ #755 PREEMPT Thu Feb 12 17:14:31 GMT 2015 armv6l GNU/Linux
pi@raspberrypi ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi ~ $ grep i2c /boot/config.txt
dtparam=i2c1=on
dtparam=i2c_arm=on
pi@raspberrypi ~ $ grep i2c /etc/modules
i2c-bcm2708
i2c-dev
pi@raspberrypi ~ $
joan
Fri Jan 15, 2016 8:32 pm
Remove i2c-bcm2708 from /etc/modules.
Fri Jan 15, 2016 8:51 pm
Can you post your whole /boot/config.txt (drop any comment # lines)?
windell747
Sat Jan 16, 2016 2:04 am
I commented out the i2c-bcm2708 from /etc/modules, but still doesn't work.
Here is my /boot/config.txt ...
dtparam=i2c1=on
dtparam=i2c_arm=on
Sat Jan 16, 2016 9:51 am
Is that the complete config.txt or is there anything else in it? Are you sure that's the one your system is using (if you're using NOOBS it may not be)?
Remove
dtparam=i2c1=on
you don't need that.
What does an lsmod # that's ell, ess, emm, oh, dee command show?
windell747
Tue Jan 19, 2016 10:24 pm
Thanks a lot for helping!
Responding inline:
Just went to the file in nano and it looks like that is the complete file.
I'm not sure how to check to make sure that the OS is using this file.
Remove
CODE: SELECT ALL
dtparam=i2c1=on
Just did this and rebooted. Same behavior.
Here you go:
pi@raspberrypi ~ $ lsmod
i2c_dev                 6709  0
evdev                  11000  6
uio_pdrv_genirq         3666  0
uio                     9897  1 uio_pdrv_genirq
joan
Tue Jan 19, 2016 10:59 pm
You are running an old kernel (3.18.7). This was around the time device tree was introduced. Unless you have a reason not to I'd update to a more recent (4.x) kernel with sudo rpi-update.
