how to connect a usb memory stick
Posted: Tue Jan 05, 2016 2:01 am
I'm trying to get Raspbian to recognize a USB memory stick. Simonsmall wrote recently:
First issue this command -
pi@raspberrypi ~ $ ls -laF /dev/disk/by-uuid/
total 0
drwxr-xr-x 2 root root 120 Jan 1 1970 ./
drwxr-xr-x 6 root root 120 Jan 1 1970 ../
lrwxrwxrwx 1 root root 15 Jan 1 1970 1A8A-8E1C -> ../../mmcblk0p1
lrwxrwxrwx 1 root root 15 Jun 21 17:53 1B97-0057 -> ../../mmcblk0p5
lrwxrwxrwx 1 root root 15 Jun 21 17:53 53990179-b4d2-8e98-1c7d-a23b681c0419 -> ../../mmcblk0p6
lrwxrwxrwx 1 root root 15 Jan 1 1970 c37891bd-e98a-97e2-81cd-b3c78d7c93b5 -> ../../mmcblk0p3
pi@raspberrypi ~ $
This shows the "devices" that the hardware knows about, in this case the parts of the SD Card that NOOBS created.
Now, plug in the thumb drive into a USB socket. Type the same thing again.
total 0
lrwxrwxrwx 1 root root 10 Jun 17 11:36 38C1-D07C -> ../../sda1
pi@raspberrypi ~ $
There is a 'new' line that shows what the thumb drive has been called, in this case "sda1")
Trouble is, in my case there is no new line with sda1 or anything else. The output is identical both times. What is wrong? I have files on the memory stick I want to use on the Pi (tar files). How do I get Raspbian to "see" the memory stick so I can hook it into the file structure? (Yes, I'm a complete newbie...)
total 0
pi@raspberrypi ~ $
total 0
pi@raspberrypi ~ $
