Sun Jan 03, 2016 7:56 pm
I have a problem logging in one of the wifi network, so I want to configure it manually, I read that's the way to do it. I managed to set the root password, and used "edit" to get into the file, but I haven't changed anything yet.
I can log on my android hot spot, but not the land based router network. I should be able to log on to any wifi signal that pops up, so I don't know why this one doesn't work. It works fine on my windows system, but nothing on the rpi.
So... it's not the password, since it shows on the desktop as I write it. Just won't connect. I want to use the pi as a router so I have to figure out what's going on.
PS: I got an error code 15, it was trying to log on many times, then it failed.... on a prior sd card that I reformatted since.
