kingk
Making the SD in Windows
Wed Aug 01, 2012 8:18 am
Hello
I have found a good alternative to Win32DiskImager -> RawDisk.
For all interested:
http://www.theoldwildweb.com/-rawdisk-l ... ility.html
Jim JKla
Re: Making the SD in Windows
Wed Aug 01, 2012 8:54 am
Just proves there's more than one way to skin a cat. ;)
sweeneylorcan
Wed Aug 01, 2012 1:33 pm
That is good, as I used the win 32 image, and it appears to read and right, but when it is all complete, the sd card is empty. I unzip the file and save it as a image and then read and right it to the sd card but it doesn't work.
bredman
Wed Aug 01, 2012 1:41 pm
sweeneylorcan wrote:That is good, as I used the win 32 image, and it appears to read and right, but when it is all complete, the sd card is empty. I unzip the file and save it as a image and then read and right it to the sd card but it doesn't work.
You should only write the image to the SD card. If you read from the SD card, you will corrupt/destroy the image file.
calebzulawski
Wed Aug 01, 2012 1:59 pm
I'm curious, how would reading corrupt the card? "Reading" should simply only view data, but not touch the card. Does this have something to do with Windows trying to edit timestamps or something similar?
itsonlyme
Wed Aug 01, 2012 2:09 pm
kingk
There is no download link on your page, (or do I need some new glasses)
bredman
calebzulawski wrote:I'm curious, how would reading corrupt the card? "Reading" should simply only view data, but not touch the card. Does this have something to do with Windows trying to edit timestamps or something similar?
It looks like the OP read from the SD card to the IMG file before trying to write from the IMG file to the SD card.
This would destroy anything which was already in the IMG file.
calebzulawski
Wed Aug 01, 2012 2:10 pm
itsonlyme wrote:kingk
Near the bottom, there's a link next to a little image of a floppy disk.
I don't blame you, that page is cluttered :roll:
kingk
Thu Aug 02, 2012 2:12 pm
I forgot to mention the raw image file must be renamed with ".imgr" extension.
