Aberdeen aquarist
Dual purpose usage?
Mon Dec 28, 2015 10:34 am
Hello, I am a total newbie to raspberry pi's and programming and have been bought a raspberry pi 2 to use. I would like to use it for live streaming and to monitor/control a marine aquarium.
I know the will be people who use them for both of these purposes and was looking for tips before I start.
Thanks in advance, I'm away to read loads :D
Alan
Navyscourge
Re: Dual purpose usage?
Mon Dec 28, 2015 2:47 pm
The Pi can run all sorts of things at the same time, limited only by the resources available to it. It (a Pi2) should easily run the streaming and aquarium monitoring programs at the same time.
Just be aware that if the aquarium monitoring is important, and the streaming program uses a lot of CPU or storage space, you might have the situation where the monitoring program is interrupted or stalled for a brief time. Consider running the aquarium monitoring on a separate Pi (e.g. PiZero ?). Get them both working first and see how it goes.
Good luck (and keep reading ;) )
