linderman
Power state of RPi and connecting the GPIOs
Thu Dec 10, 2015 3:18 pm
Hello all,
when it is safe to connect GPIOs?
Only when RPi is totally disconnected from power source?
RPi can show only red indicator?
Or the ambitious one - GPIOs can be connected when RPi is fully running?
I want to connect some LEDS and play, but i think it will be too show if after every change in the LEDS, connectors and so on i have to turn off Pi and unplug it from power source , then connect it again and start it...
BMS Doug
Re: Power state of RPi and connecting the GPIOs
Thu Dec 10, 2015 3:27 pm
Your Pi, Your risk.
I have been known to make connections "on the fly" without powering everything down but I am not to be held responsible if you short together two GPIOs and destroy the SOC.
Doug.
FTrevorGowen
Thu Dec 10, 2015 3:29 pm
linderman wrote:Hello all,
It depends upon your interpretation of "safe" ie. there is greater risk to the Pi than you. It also depends upon how you are (physically) making/breaking the connections. Generally speaking the GPIO's are not "plug'n'play" ie. it's better to plug/unplug (multiple) connections with the Pi powered down - that way you can "double-check" your "new" wiring to make sure that, for example, you haven't connected something providing more than 3.3V to a GPIO pin (which will fry the Pi).
Trev.
linderman
Thu Dec 10, 2015 4:20 pm
According to your replies i will always connect/disconnect pins when the RPi is down.
"Down" means also that the power adapter cable is unplugged right?
FTrevorGowen
Thu Dec 10, 2015 4:30 pm
linderman wrote: ...
Easier to have a switch in the uUSB cable (switched off after the software shutdown):
http://www.cpmspectrepi.webspace.virgin ... pterCables
Item "AB" above or "B" here:
http://www.cpmspectrepi.webspace.virgin ... arger.html
Trev.
linderman
Thu Dec 10, 2015 4:43 pm
Thank you for your help. "AB" device from above "is a must" for me
BMS Doug
Thu Dec 10, 2015 4:48 pm
linderman wrote:Thank you for your help. "AB" device from above "is a must" for me
I made my own.
Doug.
