Antonyvw
connecting to a network
Wed Dec 09, 2015 7:36 am
Hi folk. Im just learning about the RasPi. I have a small network at home which I want to connect my Pi to (desktop unit + a couple of laptops). How do I get it to see the network and the network to see it? On my main pc Im running win 10 through a BT hub 5. The hub can see all the devices including the Pi but none of them can see the Pi or visa versa. can anyone help please?
Edit: I should add that this is a cabled network not wifi
hansotten
Re: connecting to a network
Wed Dec 09, 2015 7:53 am
The Raspberry Pi, running Linux (I assume Raspbian) is a different machine than Windows 10 as regarding the network.
You will have to learn about IP numbers and such, the naming and filesharing of Windows is not native to the Pi out of the box. It is doable with some study, see https://www.raspberrypi.org/documentati ... te-access/ for example.
At least you should see the Raspberry Pi via a scanner program like the Advanced IP Scanner. Then you have its ip number.
And on the Pi itself, run a terminal and type ifconfig to see the network info.
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with 8 bit CPU's
ghans
Wed Dec 09, 2015 7:54 am
Can you ping devices from the Pi and vice versa ?
ghans
Antonyvw
Wed Dec 09, 2015 8:28 am
Thanks for the help.
If I try to ping any item on my network I get the following:
ping: icmp open socket: Operation not permitted
Wed Dec 09, 2015 8:51 am
Antonyvw wrote:If I try to ping any item on my network I get the following:
That's a known bug in one of the recent releases. You can fix it with "sudo chmod u+s /bin/ping". Then ping should work.
9495944760
Sat Nov 05, 2016 9:09 pm
I met the problem of "ping: icmp open socket: Operation not permitted", the command "sudo chmod u+s /bin/ping" helped me to rectify it. Now I am facing another issue. I tried to browse in Epiphany Web Browser, but it is showing a oops window. While placing the mouse pointer over the icon for internet connectivity, it showing "eth0: Configured 169.254.8.217/16". Please help me to solve this make it smooth to browse in Epiphany Browser.
Thank you,
JOSHY T R
Radio Astronomy Centre
NCRA - TIFR
drgeoff
Sat Nov 05, 2016 9:49 pm
Thank you,
Your RPi's ethernet interface does not have a proper IP address. BTHomehub5s default to using the 192.168.1 subnet and issue DHCP addresses in the range 192.168.1.64 to 192.168.1.253.
The 169.254.8.217 address is a self-generated address by the RPi when it asks for a DHCP address but for some reason does not get one.
9495944760
Sun Nov 06, 2016 11:11 am
[img]Pictures[/img]Please help me out to rectify this IP settings.
JOSHY T R
NCRA - TIFR
drgeoff
Sun Nov 06, 2016 4:58 pm
9495944760 wrote:[img]Pictures[/img]Please help me out to rectify this IP settings.
1. Please do not hijack threads. Start you own.
2. And when you do, ensure that it contains details of the problem you are having.
Sun Nov 06, 2016 5:01 pm
Please stick to your own post it is confusing and unhelpful to OP to hijack his Post
viewtopic.php?f=63&t=164955&p=1064155#p1064138
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
