krcarbo
Connection to wifi network mobile phone
Tue Dec 08, 2015 10:29 am
I have a problem for to connect my Raspberry Pi 2 at my Wifi network shared by my mobile phone. (Nokia Lumia 930 on Windows mobile 8.1)
I use a wifi dongle. http://www.amazon.fr/Edimax-EW-7811UN-N ... B003MTTJOY
The dongle works with my PC.
The security key is WPA2-AES. I have not the choice.
It is impossible to connect me. But it's possible to connect on a network not protected.
Do you have a solution please?
nickthefish
Re: Connection to wifi network mobile phone
Wed Dec 09, 2015 4:57 am
How have you configured your interfaces and wpa_supplicant files?
e.g. sudo nano /etc/network/interfaces
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="NAME OF YOUR NETWORK"
scan_ssid=1
psk="PASSWORD OF YOUR NETWORK"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
auth_alg=OPEN
Those wpa_supplicant settings work for me when connected via WPA2-AES.
JurgenRoman
Wed Dec 09, 2015 8:25 am
I use the same dongle as you. I used a tutorial by david conroy specifically for this edimax dongle and it worked!
krcarbo
Tue Dec 15, 2015 9:55 am
hello,
Thanks for your answers. I did what you explained but it doesn't work.
I think that is a problem of compatibility between the dongle and my phone because i have the same issue on my PC, i don't succeeded to connect with the dongle.
Return to “Beginners”
