Can my PI2 boot from a USB stick ?
Does it makes anydifference between SD card and USB stick ?
Do I have to use any particular tool to format and mount ?
I make use of Rufus, Win32lmanager and SDFormatting.
Re: Booting media
The Pi will ONLY boot from a SD card, with the partition formatted as FAT. This bit cannot be changed.
The remainder of the boot process, and the non-boot directories of the operating system, can be moved to a USB stick. There are quite a few different ways of setting up the Pi in this way. It depends on what you are trying to achieve
Re: Booting media
The Openelec is opening Kodi, but when I exit Kodi, the proper way, and re-start Openelec, I have to wait 120 seconds to load, because it says, files are corrupted. When Kodi opens, I loose all my addons. Should I have partitioned the drive ?
I have tried to load the OSMC, but the PI2 will not boot.
So, I am trying to use a USB stick, instead of the SD.
Note that I had previously loaded Raspbian from NOOBS on my PI2.
Re: Booting media
Ensure you are using the RPi2 version of OSMC.pawlu wrote: I have tried to load the OSMC, but the PI2 will not boot.
Re: Booting media
Hi there,
You can install OSMC to a USB stick, but you'll still need an SD card to perform the initial boot. If you head to osmc.tv/download and use our installer, this will automatically be configured for you.
Re: Booting media
Where can I find the PI2 initial boot files ? On any OS image configured for Raspberrypi ?
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: Booting media
They're on the first primary FAT partition on a regular plain Raspbian (or other distro) SDCard.
They're on partition #5 on a NOOBS card.
Re: Booting media
Thanks for your reply and patience.
Pardon my ignorance, because I am a newbie to Linux distros etc.
Just where can you see the partitions on an sd card ?
On an ISO OS image, I can see the various files and folders, kernels, OS etc.
- DougieLawson
Re: Booting media
start with sudo fdisk -l
