jbudd
A plea for a new wifi setup guide
Sat Dec 05, 2015 4:13 pm
There is a sticky thread in Troubleshooting "Wifi issues? Start here!"
Well, it has 281 replies so far. I have not read every single post but I have read enough to be thoroughly confused.
Please can we have a new sticky with a clear explanation for beginners (no, "man dhcpcd.conf" does not suffice!) of how to setup Wifi in Raspbian Jessie?
It needs to explain:
1. How to set up WiFI with the GUI both dynamic and static IP address.
2. How to set up WiFi from the command line, both dynamic and static IP address.
3. Alternatives, including purging dhcpcd and reverting to wpa_supplicant, with pros and cons.
4. The dual IP address issue: cause and solution
5. Any future plans around this area of Jessie
Thanks in advance
expandables
Re: A plea for a new wifi setup guide
Sat Dec 05, 2015 4:23 pm
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
jbudd
Sat Dec 05, 2015 4:35 pm
Are you sure that guide is basic, accurate and appropriate for beginners with Raspbian Jessie?
