juranga
edimax ew-7811un
Thu Nov 26, 2015 5:59 pm
I have a raspberry pi 2 model (raspbian jessie), and I want to use edimax ew-7811un wifi adapter. I have follow two guides to install it but I did not achieve.
I have followed this steps:
1. /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
2./etc/wpa_supplicant/wpa_supplicant.conf
network={
ssid="Euskaltel-xxx"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="TFatxxxx"
3./etc/modules
snd-bcm2835
i2c-dev
8192cu
When I write lsusb command I receive this, so the adapter is recognized.
Bus 001 Device 005: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 004: ID 046d:c534 Logitech, Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
What am I doing wrong??
Beluga
Re: edimax ew-7811un
Fri Nov 27, 2015 10:18 am
I did the installation with this script
wget "http://raspberry-at-home.com/files/ap_setup.sh"
chmod +x ap_setup.sh
sudo ./ap_setup.sh
it worked for me, than you have an access point also
dgordon42
Fri Nov 27, 2015 2:31 pm
The Edimax EW-7811Un should work "out of the box" with Raspbian Jessie.
Standard /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface eth0 inet manual
allow-hotplug wlan0
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
Standard /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
        ssid="Your WiFi SSID"
        psk="Your WiFi Password"
        key_mgmt=WPA-PSK
Also, The EW-7811 can drop the WiFi connection after a period of inactivity. The fix for this is to create the file
/etc/modprobe.d/8192cu.conf
with permissions
-rw-r--r-- root root  86 Oct 17 16:00 8192cu.conf
containing the line
options 8192cu rtw_power_mgnt=0 rtw_enusbss=0
This prevents the EW-7811 from going to sleep.
Hope this helps,
Dave.
juranga
Mon Nov 30, 2015 7:15 am
Many thanks for your help!
I will try today, I hope It is going to work fine!
juranga
Mon Nov 30, 2015 9:57 pm
It works! Many thanks for your help!
And I would like to have a static IP, is it possible this??
MrEngman
Tue Dec 01, 2015 12:18 am
juranga wrote:It works! Many thanks for your help!
Good to hear it's sorted your problem.
For a static IP you need to edit file /etc/dhcpcd.conf. There are several posts in the forum about setting a static IP. Search the forum for dhcpcd and you should find some. Or try man dhcpcd.conf.
For a wifi static IP you need to add something like this to the end of the file /etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.1.201/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
but using IP values to suit your own network.
MrEngman
juranga
Tue Dec 01, 2015 8:43 pm
I have followed this steps and the static Ip is working perfectly!
http://www.modmypi.com/blog/tutorial-ho ... ip-address
Thanks a lot for your help!
