Thanks you for your time
It shouldn't be a problem for your TV. (except when you are using high power USB devices without a hub)Richard24red wrote:I was wondering and a bit worried will it hurt the tv in anyway.
There is a chance that the hub will back power the pi, the problem with back power is that you skip the fuse (so no protection), so I think it's better to find a hub which doesn't back power.Richard24red wrote:Will that hub back power the pi and destroy it
What Model of Raspberry Pi do you have ?Richard24red wrote:Hi everyone I have two questions that are driving me and I'm new to the whole pi concept. Right my two questions are one I have my pi powered by my TV (its a smart TV kdl32705cbu sony bravia model ) and I was wondering and abit worried will it hurt the tv in anyway. My second question is I'm planning on buying a USB hub for my pi to connect a hdd portal none mains powered will that hub back power the pi and destroy it or is that just when you have a pi plugged into a hub not a hub plugged into a pi hope I made that last question clear![]()
The RPi B+ & 2B if using a quality 5v2A PSU can power a 2.5" USB Drive, see:Richard24red wrote:Thanks you for all your replys I understand about the tv its not gonna harm it thanks you![]()
Now about the hub and pi model I have the raspberry pi 2 b and I need a hub to play the external hdd wich is a portable so its not powered by anything I've tried just plugging into the pi with a USB powersupply but it won't power it just comes on for a second then off and it keeps repeating it so basically just need a hub to keep it on
Thank you
max_usb_current=1The RPi has protection circuit so powering from a Hub or TV is not an issue.Richard24red wrote:Sorry Im a bit new to the pi so your saying that if i have a usb hub to only power the hard drive that could damage my pi ?
