frivga
problem with GPIO
Mon Nov 23, 2015 6:43 pm
Hello evrybody
I have traied this tutoriel
But it gives me this error
I dont know what s the problem
pleaase give me ur help
thanksss
Navyscourge
Re: problem with GPIO
Tue Nov 24, 2015 9:39 am
Are you using Wheezy or the latest Jessie, assuming you are running the Raspbian operating system?
Are you running your Python code from a command prompt or in the Python IDE?
It looks like you need permission to set the GPIO pins state (i.e. sudo) but the best answer depends on how you are running the code.
Tue Nov 24, 2015 10:36 am
Navyscourge wrote: It looks like you need permission to set the GPIO pins state (i.e. sudo) but the best answer depends on how you are running the code.
You can avoid that with GPIOzero.
http://raspi.tv/2015/gpio-zero-introduction
frivga
Fri Nov 27, 2015 8:42 pm
I don't know exactely which system I m using
because I have bought a SD card which already instaled in order to work with an lcd touch sreen without looking for a driver....
and I m trying to run it from IDLE because I don't know any other way to do it
joan
Fri Nov 27, 2015 8:56 pm
The program wants you to run it with root privileges.
Try starting idle with sudo.
E.g. sudo idle
