ltorvalds024
Why cant I connect external hard drive with USB 2.0?
Mon Nov 09, 2015 1:40 pm
Official documentation says:
Typically, the model B uses between 700-1000mA depending on what peripherals are connected; the model A can use as little as 500mA with no peripherals attached. The maximum power the Raspberry Pi can use is 1 Amp. If you need to connect a USB device that will take the power requirements above 1 Amp, then you must connect it to an externally-powered USB hub
That means I can connect any device that uses 5V and current less than 1A.
Why cant I connect my external hard drive that operates at 5V and consumes less than 500mA (this is the maximum current USB 2.0 can provide) ?
I am using Raspberry Pi 2 and Raspbian as OS
NOTE: I am only connecting the power source (that can provide more than 1A) and a Ethernet cable
RaTTuS
Contact: Twitter YouTube
Re: Why cant I connect external hard drive with USB 2.0?
Mon Nov 09, 2015 1:53 pm
you probably can
see adding
max_usb_current=1
to the correct config.txt file which will up the current to a max of 1.2A on all 4 ports
what does dmesg say when you plug this hard disk in
if you are using a model b [old school] not b+ or b2 then other things may be needed to make it work
Covfefe
Mon Nov 09, 2015 1:54 pm
Removed as OP stated RPi B not 2B
Last edited by fruitoftheloom on Mon Nov 09, 2015 2:03 pm, edited 1 time in total.
Thinking outside the box is better than burying your head in the sand...
Mon Nov 09, 2015 1:55 pm
Last edited by fruitoftheloom on Mon Nov 09, 2015 2:04 pm, edited 1 time in total.
ltorvalds024
Mon Nov 09, 2015 2:02 pm
RaTTuS wrote:you probably can
see adding
max_usb_current=1
I am using Raspberry Pi 2 and Raspbian as OS, where can I find these settings?
Mon Nov 09, 2015 2:05 pm
see adding
max_usb_current=1
This applies to RPi1 B+ & RPi2 B
https://projects.drogon.net/testing-set ... berry-pi-b
https://www.raspberrypi.org/help/faqs/#power
RaTTuS
Mon Nov 09, 2015 2:08 pm
Covfefe
PiBrain
Mon Nov 09, 2015 2:09 pm
see adding
max_usb_current=1
I think what you're looking for is the file /boot/config.txt. Usually caution about editing system files and making backups apply.
