fandiaye
please help explain this command
Mon Nov 09, 2015 2:30 am
sudo rm -rf ~/.cache/pip
what does this command do? I'm in the process of installing OpenCV and nothing happens when i type this in.
Thanks in advance for the help
kusti8
Re: please help explain this command
Mon Nov 09, 2015 3:18 am
Rm is the command to remove files. The -r is for it to do it recursively, essentially deleting a folder and everything in it. The -f is to force it, no prompt.
W. H. Heydt
Mon Nov 09, 2015 4:29 am
man rm
will tell you all about the rm command and what the flags do. Be very, very careful with "rm -rf" because you can wipe the entire system with it.
To add ro what was said, the "sudo" at the front means that it is being run with superuser (root) privileges, which means that *nothing* will stop it from working.
stderr
Mon Nov 09, 2015 4:43 am
fandiaye wrote:sudo rm -rf ~/.cache/pip
Just because nothing is echoed back does not mean that nothing is happening.
W. H. Heydt
Mon Nov 09, 2015 4:45 am
Indeed. That is the default unix--and Linux, by derivation--behavior of commands.
