kennyt777
Just getting started. B 2 model to use for music streaming
Sun Nov 08, 2015 6:00 pm
I bought a B 2 model to use for music streaming. Trying to get it set up but I am a total newb. I have created a burned sd card using a brand new card and Moode audio. I powered the unit with a usb cord from a laptop and connected to a monitor. The lights on the board are flashing but there is no image or anything showing on the monitor. I have it connected using hdmi to dvi cable.
I have spent a fair bit of time trying to learn for myself how to get it all working but I am clearly missing something.
Any help would be great.
W. H. Heydt
Re: Just getting started.
Mon Nov 09, 2015 2:31 am
Start with this: viewtopic.php?f=28&t=58151
It may be that your laptop actually adheres to the USB 2.0 standard and will not supply more than 500mA to an attached device (the Pi in this case). Indeed, unless there is a proper "handshake", it may not provide any more that 100mA. Best to get a good 5v 2A power supply for your Pi. If you specify where you are, people can give you somewhat localized sources for add on equipment (like PSUs) that you might need.
kennyt777
Re: Just getting started. B 2 model to use for music streami
Tue Nov 10, 2015 1:27 am
Today i tried the power supply direct from the wall rather than through laptop. The lights come on but they dont blink.I thought i had read if the light doesnt flash it is because it is unable to read the card.I formatted the card and re wrote the noob file to it but still no luck.In the meantime i,m still reading and trying to learn.
stderr
Tue Nov 10, 2015 1:49 am
[quote="kennyt777"][/quote]
If you connect a passive converter from hdmi to the digital in of some monitors, it might not work. I know I couldn't get one of two monitors to work in that way when I tried it back when the original pi first came out.
If you run a program on another box like fping or fing on an android phone, you might find that your pi is booted up but just not showing anything on the display. It would be good to narrow down where your problem actually is.
Tue Nov 10, 2015 8:38 am
What are you putting on the SDCard? Start with a copy of NOOBS/Raspbian Jessie and get that working before trying anything else.
https://downloads.raspberrypi.org/NOOBS_latest
kennyt777
Tue Nov 10, 2015 12:44 pm
Thanks for they tips. I did finally get it working somewhat.The noob os did not down load fully onto the card for some reason. I formatted and re loaded it and this time all the needed files seemed to be there.I got it to the point of booting and it said there was something else it needed but it required an ethernet connection so I left it as is. I will hook it up to my router today and try it again, hopefully it will work ok this time.
kennyt777
Tue Nov 10, 2015 5:27 pm
Well now i,m really baffled. I suspected there was something going on with the sd card since the green light was no longer blinking.I started over with a different card. Formatted and re loaded noob. When i hooked it up the screen came up with the choices of programs to install but before I had the chance I got a black screen that said there was some sort of crash.
Kratos
Tue Nov 10, 2015 5:37 pm
It sounds to me like you have a bad power supply. Make sure it is at least 5V @ 1.5A.
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
kennyt777
Tue Nov 10, 2015 6:32 pm
Ok will try to find a different source and try it again. Thanks
kennyt777
Tue Nov 10, 2015 7:24 pm
Ok I did try another power supply. In every case it seems the red light is on showing it has power but I am no longer able to get any activity with the green light at all. Does this indicate a problem with the cards socket.?
Tue Nov 10, 2015 7:31 pm
Reformat & rewrite the card with a fresh copy of NOOBS/Raspbian or NOOBS Lite and try again.
kennyt777
Tue Nov 10, 2015 11:52 pm
Ok i took your advice. I started with a totally new download of noob.Even a different version. Formatted my disc and re loaded it. I now get a solid green light but no flashing indicating it is reading the card.I,m really stumped.
Wed Nov 11, 2015 4:43 am
kennyt777 wrote:Ok i took your advice. I started with a totally new download of noob.Even a different version. Formatted my disc and re loaded it. I now get a solid green light but no flashing indicating it is reading the card.I,m really stumped.
That indicates that the Pi can't even find the first "bootcode.bin" file in the root folder of the card.
What files do you see in the root of the card (D:\ or whatever in windows)?
kennyt777
Wed Nov 11, 2015 12:45 pm
Not exactly sure I understand what you asked.When I DD the files from the extracted zip file i start with the first which I believe says "images" and then just go down through the list to the end.I double checked that they are all transferred to the card as they appear in the extracted list.
Wed Nov 11, 2015 12:50 pm
With noobs you just unzip the contents of the downlaoded file to the card. You don't need to dd anything.
If you look at the card in any system, you should see those files and folders.
Archive:  NOOBS_v1_4_1.zip
  Length      Date    Time    Name
    17856  2015-02-18 16:26   bootcode.bin
      356  2015-05-11 15:53   BUILD-DATA
        0  2015-02-17 12:45   defaults/
        0  2015-02-18 16:29   defaults/slides/
    40113  2015-02-18 16:23   defaults/slides/A.png
     2250  2015-02-18 16:23   INSTRUCTIONS-README.txt
        0  2015-02-17 14:14   os/
        0  2015-05-11 15:42   os/Raspbian/
      439  2015-02-17 14:50   os/Raspbian/flavours.json
     2439  2015-05-07 01:00   os/Raspbian/release_notes.txt
      357  2015-05-11 15:44   os/Raspbian/os.json
 10988320  2015-05-07 00:31   os/Raspbian/boot.tar.xz
        0  2015-02-17 14:15   os/Raspbian/slides_vga/
    38637  2013-06-20 16:37   os/Raspbian/slides_vga/B.png
    33646  2013-06-20 16:37   os/Raspbian/slides_vga/G.png
    28172  2013-06-20 16:37   os/Raspbian/slides_vga/D.png
    29776  2013-06-20 16:37   os/Raspbian/slides_vga/E.png
    35337  2013-06-20 16:37   os/Raspbian/slides_vga/F.png
    27682  2013-06-20 16:37   os/Raspbian/slides_vga/C.png
    39806  2013-06-20 16:37   os/Raspbian/slides_vga/A.png
744022392  2015-05-07 01:00   os/Raspbian/root.tar.xz
     2857  2013-10-13 16:46   os/Raspbian/Raspbian_-_Boot_to_Scratch.png
     1662  2013-06-20 16:36   os/Raspbian/Raspbian.png
      414  2015-05-11 15:24   os/Raspbian/partitions.json
      420  2015-02-16 15:09   os/Raspbian/partition_setup.sh
        0  2015-02-07 01:48   os/Data_Partition/
      164  2014-09-10 03:16   os/Data_Partition/os.json
     1335  2013-10-14 18:55   os/Data_Partition/Data_Partition.png
      225  2014-09-10 03:16   os/Data_Partition/partitions.json
      332  2013-10-14 18:55   os/Data_Partition/data.tar.xz
  2148120  2015-02-18 16:24   recovery7.img
       54  2015-02-18 16:26   recovery.cmdline
   554520  2015-02-18 16:26   recovery.elf
        0  2015-02-18 16:26   RECOVERY_FILES_DO_NOT_EDIT
  2100464  2015-02-18 16:26   recovery.img
 20238331  2015-02-18 16:26   recovery.rfs
     9728  2015-02-18 16:23   riscos-boot.bin
780366204                     37 files
kennyt777
Wed Nov 11, 2015 4:57 pm
Ok thanks. I will have a closer look. Is there a limit to the number of times a card can be formatted? Mine has been done a few times now.
Wed Nov 11, 2015 6:22 pm
kennyt777 wrote:Ok thanks. I will have a closer look. Is there a limit to the number of times a card can be formatted? Mine has been done a few times now.
You will eventually wear it out, but it will take a long time. A full format should only write to each block once or twice, and they are designed to handle many thousands of write cycles each.
kennyt777
Wed Nov 11, 2015 7:25 pm
Ok thanks. I seem to be making some progress. I got it to start the boot up and it got to the point where I had to select the OS I wanted to install. But when I try to choose one it says there is zero room left on the disc which is odd because it was an 8gb disc.I have a 16 that I am re formatting and will try again. I am only able to do an over write format.It will not allow me to do a full erase. Not sure if that is a problem or not.
kennyt777
Wed Nov 11, 2015 8:10 pm
I did it. Thanks to everyone who helped. Its installed and seams to be working perfectly. Now the fun begins.
