jscott13
wpa_supplicant blank?
Mon Nov 02, 2015 1:28 am
Should wpa_supplicant.conf be blank after booting? After editing this file, seemingly correcting a connection issue by doing so, I then returned a few hours later restarted the pi and had the same connection issues. I checked the conf and it was blank.
The original issue is posted here as the post "Net Connection?"
KLL
Re: wpa_supplicant blank?
Mon Nov 02, 2015 3:31 am
jscott13 wrote:Should wpa_supplicant.conf be blank after booting? After editing this file, seemingly correcting a connection issue by doing so, I then returned a few hours later restarted the pi and had the same connection issues. I checked the conf and it was blank.
[email protected] ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
for edit use
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
if you use the dhcpcdui from desktop [ network icon ] and try to configure your SSID / password
( what would be the usual way to do it / not a manual edit / )
that should write into that file.
a combination of manual edit and using the desktop tool easy goes wrong.
