koos147
high power usage
Sun Nov 01, 2015 5:34 pm
Hey
I want to use a 16x relay board on my raspberry pi 2 B.
i have a 2.5A power supply.
The board is using 1A when all relays are on.
i am a little bit afraid to power them through a 5V GPIO pin.
do i need to have a separate power supply for this board?
Regards
Mark
Re: high power usage
Sun Nov 01, 2015 7:32 pm
That should be OK as long as your power supply and microUSB cable are good enough.
I did that using an MCP32017 running at 5V0 as the GPIO controller for 16 5V0 coil relays.
JimmyN
Mon Nov 02, 2015 11:03 am
When everything is up and running measure the voltage across RPi board pins #4 (5V) and #6 (GND) with all the relays "on". If that voltage is in range your PS and power cable are adequate.
