disorientedp
Static IP Address on Raspbian Jessie [SOLVED]
Tue Oct 27, 2015 11:19 pm
I've been having trouble setting up a static IP in Jessie. I can't find any guides that cover it, as the interfaces file has changed. I tried reading the man page suggested in a comment in the interfaces file, but couldn't figure it out.
MrEngman
Re: Static IP Address on Raspbian Jessie
Tue Oct 27, 2015 11:47 pm
disorientedp wrote:I've been having trouble setting up a static IP in Jessie. I can't find any guides that cover it, as the interfaces file has changed. I tried reading the man page suggested in a comment in the interfaces file, but couldn't figure it out.
Looking at the /etc/network/interfaces file in jessie it includes the following two lines
# Please note that this file is written to be used with dhcpcd.
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'.
MrEngman
disorientedp
Wed Oct 28, 2015 1:28 am
MrEngman
Right. I can't figure out how to configure dhcpcd.conf for a static IP.
disorientedp
Wed Oct 28, 2015 2:02 am
I guess I'm not really sure how to find all the information I need for this configuration. How do I choose what IP address I should use?
Here is what I have in the /etc/dhcpcd.conf file (The full contents):
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface wlan0
static ip_address=192.168.0.30/255.255.255.0
static routers=10.0.1.1
static domain_name_servers=10.0.1.1
KLL
Wed Oct 28, 2015 2:53 am
what you try to do?
why you want a static IP for WIFI
if you need to ask what IP to use you should not do a change in /etc/dhcpcd.conf at all
the reason for dhcpcd is to do it all for you
after the connection works ( like ethernet cable to router and wifi adapter to wifi ssid router )
you can document IP of router(s), and wlan0 IP and eth0 IP.
you can use that IPs to connect remotely from any computer in the same network
only if you have full knowledge / control over your network you can use static IP later, like if the RPI needs to be a network server...
so what was the router IP, the RPI eth0 IP and RPI wlan0 IP prior to your change?
if your WIFI router is at 10.0.1.1
your RPI IP could be 10.0.1.30 ( if free ) but never 192.168.0.30
if the .30 given by router automatically ( check router settings DHCP IP Address Range : from
to ) it is more nice to use a IP what is outside of the automatic range.
my ADSL router has IP 192.168.1.1, so i use ( at the end of ) /etc/dhcpcd.conf
interface eth0
static ip_address=192.168.1.101/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
interface wlan0
static ip_address=192.168.1.201/24
and in desktop top right i see
http://kll.engineering-news.org/kllfusi ... d_conf.png
klricks
Wed Oct 28, 2015 5:30 am
IMO it is much easier to setup a DHCP reservation for the RPi (MAC address) in your router. That way the router always assigns the same IP of your choice and there is no config changes at all to do on the RPi.
disorientedp
Wed Oct 28, 2015 12:05 pm
Okay, I got it to work. Thanks for the help; I'm a bit slow at times. Now I won't have to bother with memorizing an IP address that changes every few days...
JayS
Sat Nov 07, 2015 9:09 pm
klricks wrote:IMO it is much easier to setup a DHCP reservation for the RPi (MAC address) in your router. That way the router always assigns the same IP of your choice and there is no config changes at all to do on the RPi.
I agree. I am new to all the network settings and I tried to set a static IP within Raspian for a print server but never quite got it right. I found the address reservation setting in my router and have had no problems since.
Enjoy the ride,
Jay
Fast enough to get there...slow enough to see
stderr
Sat Nov 07, 2015 10:02 pm
disorientedp wrote:Okay, I got it to work. Thanks for the help; I'm a bit slow at times. Now I won't have to bother with memorizing an IP address that changes every few days...
Usually you'd put that in your hosts file so that the name could then be used in most situations.
Henk B
Re: Static IP Address on Raspbian Jessie [SOLVED]
Sun Dec 06, 2015 7:02 pm
I have managed the static ip address with the crontab, add to sudo crontab -e: @reboot sudo ifconfig eth0 192.168.2.1
and reboot the RPi, this solved mi problem to manage the IP address...
bobe001
Wed Dec 09, 2015 11:04 pm
Hi I've found that using the solution as explained above, while giving you a static address completely screws the ntp function
stderr
Wed Dec 09, 2015 11:57 pm
bobe001 wrote:Hi I've found that using the solution as explained above, while giving you a static address completely screws the ntp function
When doing this, is there already a dhcp address set up for that adapter? I mean if you look at eth0, do you get something sane just something that you can't seem to stop from changing? Because, perhaps, you could modify the idea the other person had to the following:
sudo crontab -e: @reboot sudo ifconfig eth0:1 192.168.2.1
The idea would be to keep the dhcp address but then add in your own static one. I also would think about changing the static address from ending in .1 since that is often what routers are set at. Find out also where your dhcp addresses are and avoid those.
bobe001
Thu Dec 10, 2015 9:18 am
Hi no I do get a sane ip allotted to me but because the pic will be working headless in a remote location I have to have a static ip to reach it. Using frontal does work for me however to not be able to use the documented method must mean Jessie has a bug.
jbudd
Thu Dec 10, 2015 12:05 pm
I agree, Raspbian Jessie does appear to have a bug.
This is my limited understanding of how we should assign a static IP within Jessie:
/etc/network/interfaces should be the original unedited:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
/etc/wpa_supplicant/wpa_supplicant.conf contains your router ssid and password
update_config=1
network={
    ssid="BTHub3-FR0B"
    psk="09a87b65cd"
And at the bottom of /etc/dhcpcd.conf define your static IP setup. Of course the actual values have to match your network setup
interface wlan0
static ip_address=192.168.1.140/24
static domain_name_servers=192.168.1.1 8.8.8.8
interface eth0
static ip_address=192.168.1.147/24
If you do the above you may end up with two IP addresses, your static one and a variable DHCP one.
I think that in /etc/network/interfaces "iface xxxx inet manual" means that the interface should not be assigned a DHCP IP address, but it is. This is where the bug is in Raspbian, imho.
karrika
Thu Dec 10, 2015 12:15 pm
In the Ubuntu world the /etc/network/interfaces is honored by the automatic wizardry of Network Manager. It would be nice if Jessie would do the same.
smithy468
Sun Dec 20, 2015 8:31 am
I messed around with this for a while and found that I was able to get a static IP by adding only
interface eth0
interface wlan0
to the dhcpcd.conf file. Could someone explain what the static routers IP and static domain_name_servers IP are there for? I'm sure they have some purpose, but it seems to work without them..
Sun Dec 20, 2015 9:00 am
smithy468 wrote:Could someone explain what the static routers IP and static domain_name_servers IP are there for? I'm sure they have some purpose, but it seems to work without them.
Without those entries you shouldn't be able to get to anything outside your own 192.168.1.0 network range (the routers entry), and shouldn't be able to access any remote service by name, like raspberrypi.org (the domain_name_servers entry).
Unless you have added in a router/gateway with the route command, and added a DNS entry to /etc/resolv.conf.
Out of interest, what do "ip route" and "cat /etc/resolv.conf" show?
smithy468
Tue Dec 22, 2015 6:02 am
Thank you, you are right... Doing
sudo ping 8.8.8.8
(Google DNS) gives a "network is unreachable" error.
ip route shows:
10.0.0.0/8 dev wlan0  proto kernel  scope link  src 10.0.0.98  metric 303
169.254.0.0/16 dev eth0  proto kernel  scope link  src 169.254.81.98  metric 202
cat /etc/resolv.conf shows:
# Generated by resolvconf
nameserver 2001:558:feed::1
nameserver 2001:558:feed::2
Tue Dec 22, 2015 6:28 am
Ok, something is very wrong with your networking setup.
You have set a static address of 192.168.1.101 for wired and 192.168.1.201 for wireless, but your routing is showing a 10.x.x.x subnet for the wireless and a 169.254.x.x (can't get a real address via DHCP) subnet for the wired.
The entries in resolv.conf show only ipv6 addresses, no ipv4.
Please post the full contents of /etc/network/interfaces and /etc/dhcpcd.conf
smithy468
Tue Dec 22, 2015 6:58 am
So the IP addresses I posted above were just from the examples... For eth0 I'm using 169.254.81.98 and wlan0 is 10.0.0.98.
Here is the /etc/dhcpcd.conf file contents:
#controlgroup wheel
hostname
clientid
# or
#duid
persistent
option rapid_commit
option ntp_servers
slaac private
interface eth0
static ip_address=169.254.81.98
static routers=169.254.1.1
static domain_name_servers=169.254.1.1
interface wlan0
static ip_address=10.0.0.98
static routers=10.0.0.1
static domain_name_servers=10.0.0.1
Here is my /etc/network/interfaces file:
auto lo
allow-hotplug wlan0
allow-hotplug wlan1
Tue Dec 22, 2015 10:04 am
You can't have a static router in the 169.254.xxx.xxx/16 subnet. That network block is not routable.
This is a doctor free zone.
smithy468
Wed Dec 23, 2015 2:49 am
I guess I should clarify, I'm connecting the Pi directly to my PC via ethernet. The IP of my laptop's ethernet adapter is 169.254.81.99, so I changed the last number of it when assigning the static IP of my Pi. I did get it to work with:
interface eth0
static routers=169.254.0.0
static domain_name_servers=75.75.75.75 75.75.76.76 2001:558:feed::1 2001:558:feed::2
interface wlan0
I copied the domain name servers from the resolv.conf file on a clean install of Jessie. Do you see any conflicts/ problems doing it this way?
Wed Dec 23, 2015 8:12 am
Get rid of
because it will break your networking. 169.254.xxx.xxx/16 is the link-local address block and shouldn't be used as a default route.
smithy468
Wed Dec 23, 2015 11:50 am
Ok, will do, thanks.... But what should be used instead? Or should I just omit the line entirely?
