Hey Doug, like always thanks for the reply. I read that before I posted and I still am not sure what my "topic" would be in my case.
Or maybe the answer is, the "topic" doesn't matter for my case as long as it follows the specification?
Edit1.0: just read your sig, and saw the MQTT Evangelist
I just learned what it was the other day and how I can use it in my automation research, so I will keep reading and keep working on understanding it.
Edit1.1: Figured I might add the python code I am using on my pi broker (maybe it might help)
import paho.mqtt.client as paho
import RPi.GPIO as GPIO
import json, time
# device credentials
device_id = 'admin' # * set your device id (will be the MQTT client username)
device_secret = '313131' # * set your device secret (will be the MQTT client password)
random_client_id = 'MQTT' # * set a random client_id (max 23 char)
# Board settings #
buttonPin = 7
ledPin = 12
GPIO.setmode(GPIO.BOARD) # use P1 header pin numbering convention
GPIO.cleanup() # clean up resources
GPIO.setup(ledPin, GPIO.OUT) # led pin setup
GPIO.setup(buttonPin, GPIO.IN) # button pin setup
# Callback events #
# connection event
def on_connect(client, data, flags, rc):
print('Connected, rc: ' + str(rc))
# subscription event
def on_subscribe(client, userdata, mid, gqos):
print('Subscribed: ' + str(mid))
# received message event
def on_message(client, obj, msg):
# get the JSON message
json_data = msg.payload
# check the status property value
print(json_data)
value = json.loads(json_data)['properties'][0]['value']
if value == 'on':
led_status = GPIO.HIGH
GPIO.output(ledPin, GPIO.HIGH)
else:
led_status = GPIO.LOW
GPIO.output(ledPin, GPIO.LOW)
# confirm changes to Leylan
client.publish(out_topic, json_data)
# MQTT settings #
# create the MQTT client
client = paho.Client(client_id=random_client_id, protocol=paho.MQTTv31) # * set a random string (max 23 chars)
# assign event callbacks
client.on_message = on_message
client.on_connect = on_connect
client.on_subscribe = on_subscribe
# device topics
in_topic = 'devices/' + device_id + '/get' # receiving messages
out_topic = 'devices/' + device_id + '/set' # publishing messages
# client connection
client.username_pw_set(device_id, device_secret) # MQTT server credentials
client.connect("178.62.108.47") # MQTT server address
client.subscribe(in_topic, 0) # MQTT subscribtion (with QoS level 0)
# Button logic #
prev_status = GPIO.LOW
updated_at = 0 # the last time the output pin was toggled
debounce = 0.2 # the debounce time, increase if the output flickers
# Continue the network loop, exit when an error occurs
rc = 0
while rc == 0:
rc = client.loop()
button = GPIO.input(buttonPin)
if button != prev_status and time.time() - updated_at > debounce:
prev_status = button
updated_at = time.time()
if button:
led_status = not led_status
button_payload = 'off'
if led_status == GPIO.HIGH:
button_payload = 'on'
# effectively update the light status
GPIO.output(ledPin, led_status)
payload = { 'properties': [{ 'id': '518be5a700045e1521000001', 'value': button_payload }] }
client.publish(out_topic, json.dumps(payload))
print('rc: ' + str(rc))
Edit1.2: the actual code says what the topics are, I just blindly didn't look hard enough.
devices/<DEVICE-ID>/get
Just not sure if it's 'get' or 'set' because the broker is receiving the clients request to change the light so I think it will be 'get'
