simplified
3TB Hard Drive Issue
Tue Jul 24, 2012 8:05 pm
Hi All
I've tried mounting a 200GB HDD with no problem just to "see it working" and thought great - I'll go all out and buy a 3TB HDD that I can then use to utilise the RPi as a backup server/squid proxy etc. for the home.
When I ran fdisk on the USB connected 3TB drive, it was shocked to see that it showed up as 801.6GB rather than it's true 3TB.
A long googling session started and I found that recompiling the Kernel with the "CONFIG_EFI_PARTITION to y" was required, so I went about doing this. Rather than compile on a faster machine, I decided to compile on the RPi itself.
6 hours later....
The Kernel had compiled and after following the instructions meticulously I copied the relevant files into /boot and restarted.
I went through the (gnu) parted instructions and ran fdisk again to see what the result was. Alas, this showed up as 801.6GB still.
I'm not really sure where to go from here and whilst I'm not an expert at Linux I'm not adverse to "having a go". If anyone can share an experience that they have had with large HDD's and the RPi I'd love to hear them and any advice would be most appreciated on where to go next.
Cheers, Ollie
obarthelemy
Re: 3TB Hard Drive Issue
Tue Jul 24, 2012 8:20 pm
I have a 3TB hard drive too, not an a Pi though. The issue is your drive must be partitioned using a GPT/GUID, not MBR, format. Broadly speaking, GPT is supported by machines with an EFI Bios.
If you have already partitioned your drive to MBR, you need to re-do it. There are also a number of Linux and Windows tools to convert from MBR to GPT, though if there's no data on your drive yet I'd probably start from scratch.
The bad news is I have no clue where GPT support in the Pi is at, especially since it doesn't use BIOS/EFI, s even once your drive is in GPT, I'm not 100% sure the Pi will be able to deal with that.
simplified
Tue Jul 24, 2012 10:38 pm
Thanks for the reply! I've tried to follow the instructions here:
http://elinux.org/RPi_Kernel_Compilation
...to recompile the kernel based on the fact that the EFI component of the kernel was missing, and then went on to follow these instructions to create the gpt:
http://icesquare.com/wordpress/how-to-i ... -on-linux/
It seems to me that you're right in that this is an issue with HWvrather than software; I'll keep plugging away and will post the answer if I ever get there...
When you say start from scratch, do you mean delete all partitions and start again? If you could give me a pointer on how to do this that would be great as I deleted everything in "parted", wrote settings and then tried again, but encountered the same ~800GB issue.
Cheers, OL
itimpi
Wed Jul 25, 2012 1:32 pm
Note that you cannot use fdisk with a 3TB drive as it does not understand the GPT partitioning scheme.
simplified
Wed Jul 25, 2012 3:35 pm
Hi Itimpi
Thanks, I knew that one already :)
I've beaten my head against the wall with this for too long now and I've given up, taken the 3TB drive back to the shop and downgraded to a 2TB drive which works just fine.
Thanks for the responses! Cheers, OL 8-)
Dkrysak
Tue Aug 21, 2012 5:06 pm
simplified wrote:Hi All
6 hours later....
Can you point me to the directions you used to enable this? (Assuming it is specific to enabling the EFI support and not the http://elinux.org/RPi_Kernel_Compilation link) I'm currently having a go at this, and want to try compiling the option in on my pi (Raspian). I had an issue with my 3TB drive when I partitioned it with parted. So i was hoping to compile the kernel, and try with the disk i had used gdisk on.
elatllat
Wed Aug 22, 2012 3:33 am
related: http://www.raspberrypi.org/phpBB3/viewt ... 28&t=15292
I have never tried pvcreate on a 3 or 4 TB drive but it's worth a try:
apt-get install lvm2
blkid
pvcreate /dev/sdg
vgcreate test_vg /dev/sdg
vgdisplay test_vg | grep Total
# Total PE              1430793
lvcreate -l 1430793 test_vg -n test_lv
mke2fs -m 0 -t ext4 /dev/test_vg/test_lv
mount /dev/test_vg/test_lv /media/test_fs
df -h
I use an 8TB ext4 partition in dm-crypt in LMV on the rpi without a problem.
You can skip the encryption but you should all be using LVM anyway :)
32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
elatllat
Wed Aug 22, 2012 3:47 am
Dkrysak wrote:...Can you point me to the directions you used to enable this...
you have the right link, you just need to edit the config before you build... though EFI is already enabled so the problem might just be they were using the wrong tools (fdisk).
current config PARTITION settings:
zcat /proc/config.gz |grep PARTITION
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
CONFIG_MAC_PARTITION=y
CONFIG_MSDOS_PARTITION=y
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
Dkrysak
Wed Aug 22, 2012 4:46 am
Thanks for the clarification! I was not using fdisk. I was using gdisk. I'll keep looking around.
Dkrysak
Wed Aug 22, 2012 4:52 am
elatllat wrote:related: http://www.raspberrypi.org/phpBB3/viewt ... 28&t=15292
blkid
pvcreate /dev/sdg
# Total PE              1430793
df -h
I was just thinking about this, but if gdisk does not see the disk as the full 3tb, LVM probably will not either. Just a though. But I'll have a go.
elatllat
Sun Sep 16, 2012 1:26 pm
Did you try LVM on your 3TB drive yet?
Dkrysak
Sun Sep 16, 2012 3:35 pm
elatllat wrote:Did you try LVM on your 3TB drive yet?
I have not. Life got in the way. :)
I was going to come back to it next week.
Picanto
Tue Jan 01, 2013 1:23 pm
blkid
pvcreate /dev/sdg
# Total PE              1430793
df -h
Tried with no luck. Still shows up as 735GB. :(
zhuanyi
Tue Jul 23, 2013 2:36 am
What is your parted -l output?
Try to use parted to identify the actual data partition and mount that (it is normally /dev/sd*2).
teeth_03
Tue Jul 23, 2013 10:16 am
Nice thread necro
On that note, my NasPi uses 2x3TB Seagate external drives that worked out of the box after using gparted to format them
Morphy99
Mon Jan 13, 2014 10:16 pm
I'm not having much luck with this, trying to get a 3TB WD Red working and tried 3 different enclosures so far.
When using lvm2 I get:
Setting up LVM Volume Groups...  No volume groups found
done.
Then
sudo pvcreate /dev/sdb
Device /dev/sdb not found (or ignored by filtering).[/code
sdb is my drive as have usb pen drive with system on it.
Blkid:
[code]~ $ sudo blkid
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="boot" UUID="EF0C-B2BE" TYPE="vfat"
/dev/mmcblk0p2: UUID="280a5334-c561-41c3-a9bf-b7a42ca61990" TYPE="ext4"
/dev/sda5: UUID="280a5334-c561-41c3-a9bf-b7a42ca61990" TYPE="ext4"
fdisk:
~ $ sudo fdisk -l
Disk /dev/mmcblk0: 3980 MB, 3980394496 bytes
4 heads, 16 sectors/track, 121472 cylinders, total 7774208 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00099f20
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1            8192      122879       57344    c  W95 FAT32 (LBA)
/dev/mmcblk0p2          122880     7774207     3825664   83  Linux
Disk /dev/sda: 7743 MB, 7743995904 bytes
117 heads, 7 sectors/track, 18467 cylinders, total 15124992 sectors
Disk identifier: 0x000987f2
/dev/sda1            1985    15124479     7561247+   f  W95 Ext'd (LBA)
/dev/sda5            2048    15124479     7561216   83  Linux
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 801.6 GB, 801569726464 bytes
256 heads, 63 sectors/track, 97071 cylinders, total 1565565872 sectors
Disk identifier: 0x01e3cd58
/dev/sdb1               1  4294967295  2147483647+  ee  GPT
Parted:
~ $ sudo parted -l
Model:  USB DISK 3.0 (scsi)
Disk /dev/sda: 7744MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number  Start   End     Size    Type      File system  Flags
 1      1016kB  7744MB  7743MB  extended               lba
 5      1049kB  7744MB  7743MB  logical   ext4
Error: Invalid argument during seek for read on /dev/sdb
Retry/Ignore/Cancel?
Can't boot with the drive connected formatted as ext4 as boot halts with a kernel panic when it tries to mount it. Boots formatted as NTFS weirdly.
Return to “Beginners”
