mjflynt
Multiple Desktops in Jessie
Sat Oct 03, 2015 1:58 pm
I was able to do this quite easily in Wheezy, but I cannot find anything analogous to "windows settings" in Jessie. Mind you - I can add desktops with no problem, but they don't stick. Any help is appreciated!
Here is the website and instuctions that used to work:
search.php?keywords=windows+settings
To set up multiple desktops do the following:
Click Menu,
Then Preferences;
Then Windows Settings;
From the Configuration manager choose Desktops in the left hand column;
Select the desired Number of Desktops;
Then click Close.
You now have multiple desktops, However, the GUI does not give any indication of this and you need to remember the keyboard shortcuts to use them: Ctrl + Alt + Left/Right will switch to the next desktop. To make this more usable do the following:
Right Click on the menu bar at the top of the screen;
Select Add/Remove Panel Items;
Select the Panel Applets Tab;
Click the Add button;
Choose Desktop Pager from the list;
Optional, choose Desktop Number/Workspace Name;
Click Close.
This will add a panel applet to the menu bar (far right by default) that will allow you to click and switch between the desktops.
KLL
Re: Multiple Desktops in Jessie
Sun Oct 04, 2015 11:58 am
mjflynt wrote: Click Menu,
Then Preferences;
Then click Close.
for me its on
/ Menu / Preferences / Open Box Configuration Manager / TAB Desktops / increase Number of Desktops / click Desktop Names and overwrite (rename ) them /
katjav
Sun Oct 04, 2015 8:39 pm
Not sure if it's just me but Open Box Configuration Manager was not in the Preferences menu of my Raspbian Jessie install. Package 'obconf' was not installed by default. I installed that and then got Open Box Configuration Manager in Preferences.
Katja
mjflynt
Tue Oct 06, 2015 7:19 am
Thank you gentle people!
I combined the info from both the above posts by using:
sudo apt-get install obconf
to get the open box configurator, and I made the changes suggested. And it stuck! Thanks so much!
Aandrew7
Sat Jan 20, 2018 8:48 pm
What are the Hotkeys for switching screens? Ctrl+Alt +Left or Right does not work.
matrix321
Mon Feb 05, 2018 9:58 pm
Try
Shift Alt Left/Right
It works for me in Raspian Stretch.
matrix321
Mon Feb 05, 2018 10:12 pm
You can find your current shortcuts in
~/.config/openbox/lxde-pi-rc.xml
klricks
Tue Feb 06, 2018 12:25 am
There is a list of defaults here: https://wiki.debian.org/Openbox
[Shift] + [Alt] + [Left] or [Right] moves the current window left or right but does not change desktops
[Windows] + [F1]...[F2] etc sorta works if you press the windows key 2 x so that the menu is closed then quickly press [Windows] + [F1] again.
This works: Moves the current window to next desktop
[Shift] + [Alt] + [Right]
n67
Tue Feb 06, 2018 12:44 am
You can also switch desktops by running the wheel on the mouse with the mouse over the desktop.
(If you have a wheel mouse, of course)
This is both very convenient and very annoying (because I often do it by mistake).
"L'enfer, c'est les autres"
Epmu Sn!
matrix321
Tue Feb 06, 2018 9:59 am
Try
Sorry of course this was a mistake. With this shortcut you move only the active window to the next dektop....
PeterO
Tue Feb 06, 2018 12:33 pm
There is a desktop pager that you can add to your tool bar.
PeterO
