Mahan_Micro
problem with Serial
Wed Sep 23, 2015 7:14 pm
Hi
I want to send and recieve by serial port but in python when I type following code:
import serial
port = serial.Serial("/dev/ttyAMA0", baudrate=115200, timeout=3.0)
while True:
port.write("\r\nSay something:")
rcv = port.read(10)
port.write("\r\nYou sent:" + repr(rcv))
it has one Syntax error in (baudrate=115200) because of = !!!!!
can you help me??
If your Dreams Don't Scare You , They Aren't Big Enough
joan
Re: problem with Serial
Wed Sep 23, 2015 7:49 pm
Could you cut&paste the script and put it within
[/b] [b]
[/b] quotes?
Similarly could you cut&paste the exact error message?
Mahan_Micro
Thu Sep 24, 2015 5:36 am
this is my code:
import serial
while True:
    rcv = port.read(10)
there is no error message.I have a syntax error
when I run the code, a Syntax error apear,because of = in line : baudrate=115200
Thank you
Thu Sep 24, 2015 5:52 am
I think you don't need to put the "baudrate=" part, just the number.
port = serial.Serial("/dev/ttyAMA0", 115200, timeout=3.0)
joan
Thu Sep 24, 2015 6:23 am
Cut&paste the syntax error.
Mahan_Micro
Tue Sep 29, 2015 6:48 am
I change the code and have not syntax error but I have another error
my simple code is:
import serial
import os
ser=serial.Serial('/dev/ttyAMA0',115200)
ser.write ('Mahan')
and when I run it :
  File "/home/pi/test.py", line 5, in <module>
    ser.write ('Mahan')
  File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 471, in write
    n = os.write(self.fd, d)
TypeError: 'str' does not support the buffer interface
I cant use the serial port and I dont know why !!!
ame
Tue Sep 29, 2015 6:57 am
