jrraines
noob ssh question
Sat Jul 21, 2012 5:38 pm
I am new to ssh. I connected my raspberry pi to a monitor and an apple keyboard and wheezy works but the Apple keyboard was very spotty, dropping almost as many keystrokes as it read. It didn't seem to work at all when a mouse was plugged in, too. I don't have a powered USB hub on hand and my goal in the near term was to try to use it in a headless mode, so moving to that promptly seemed like the thing to do. I did use the menu to enable ssh. I plugged the rpi into a router and I THINK its assigned address is 192.168.1.146. I did not change the password yet. The keyboard was so spotty that without echo I'd have had no idea what had been assigned.
on my Mac, in terminal, I tried:
Macintosh-4:~ raine001$ ssh 192.168.1.146
The authenticity of host '192.168.1.146 (192.168.1.146)' can't be established.
RSA key fingerprint is a8:28:b6:8d:ce:23:f8:fc:cc:96:54:83:fd:ea:f4:38.
Are you sure you want to continue connecting (yes/no)? y
Please type 'yes' or 'no': yes
Warning: Permanently added '192.168.1.146' (RSA) to the list of known hosts.
raine001@192.168.1.146's password:
Permission denied, please try again.
Permission denied (publickey,password).
Macintosh-4:~ raine001$ ssh 192.168.1.140
ssh: connect to host 192.168.1.140 port 22: Connection refused
Macintosh-4:~ raine001$ ssh 192.168.1.148
^Z
[1]+ Stopped ssh 192.168.1.148
I've tried 'raspberry' and 'pi@raspberry' as passwords. I'm not sure what to do, what to read, how to look for more info at this point.
asb
Re: noob ssh question
Sat Jul 21, 2012 5:39 pm
You want to ssh in as the pi user, so ssh -lpi 192.168.1.146
Joe Schmoe
Sat Jul 21, 2012 5:43 pm
asb wrote:You want to ssh in as the pi user, so ssh -lpi 192.168.1.146
More simply: pi@192.168....
I used to use -l, but once I found that the @ syntax works just as well, I stopped using -l.
jrraines
Sat Jul 21, 2012 5:59 pm
thanks!
W. H. Heydt
Sun Jul 22, 2012 6:51 am
Or...you can download PuTTY (I'm taking a shot in the dark assumption that there's a Mac version...) and
use that. When you connect, you'll get a normal login prompt.
Jim JKla
Sun Jul 22, 2012 6:54 am
Theres some usefull info in the wiki about ssh for noob users over on the wiki.
AndrewS
Sun Jul 22, 2012 6:45 pm
Jim JKla wrote:Theres some usefull info in the wiki about ssh for noob users over on the wiki.
When referring users to the wiki, some noob users don't know how to navigate/search the wiki (there are a LOT of pages on there!) so it's generally a good idea to provide direct links to the specific pages, if possible. (I haven't provided any links here either, but that's because I wasn't sure which page you were referring to)
B4GG
Wed Aug 01, 2012 5:18 am
Both here " http://elinux.org/RPi_Beginners " and here " http://elinux.org/RPi_Remote_Access " are useful starts to shh with the pi... also a noob here, but a quick search led me there!
