Mahan_Micro
my simple program in GEANY
Tue Sep 08, 2015 5:54 am
Hi
I write a simple code that only turns on an LED for me
by C in geany
this is my code:
#include <bcm2835.h>
int main(int argc,char **argv){
if (!bcm2835_init()) return 1;
bcm2835_gpio_fsel(18,BCM2835_GPIO_FSEL_OUTP);
while(1){
bcm2835_gpio_set(18);
there is no error in compile and build
but when I run this code , my led is off !! and dont change
my circiut is right :!:
whats your idea ?? :?: :?:
If your Dreams Don't Scare You , They Aren't Big Enough
GerardWassink
Re: my simple program in GEANY
Tue Sep 08, 2015 7:34 am
Perhaps try this:
	while(1) {
//		bcm2835_gpio_set(18);
		bcm2835_gpio_write(18, 1);
Not sure why you code the while forever loop, you could do without in this sample.
Succes!
Gerard
---------ooooO----- \\\\\|/// -----Oooo--------
Hacker on ELF-II, ZX80/1, Commodore 64, 8080, x86,
IBM 370 family mainframes
Machine code! Assembly! C good second.
Running Pi's with Hercules and S/370 OS's
-------------oooO-----------Oooo-------------
Mahan_Micro
Tue Sep 08, 2015 9:09 am
GerardWassink wrote:Perhaps try this:
	while(1) {
Succes!
Gerard
I tested it but my LED wass off too !!
while loop : because first I write a flasher code and when I see it doesnt work I change it
I tested the LED too
thanks for your help
Mahan_Micro
Thu Sep 10, 2015 8:45 pm
ise there any idea for my problem??
my gpio is right , with python I test it but in C don't work !!
buja
Thu Sep 10, 2015 9:05 pm
Maybe it's a rights issue, can you run it with sudo from the command line?
sudo yourprogram
Return to “Beginners”
