lucian_v
electrical precision measure
Mon Aug 31, 2015 11:44 am
Hi all,
I want to build a personal project which require to measure some force sensors which have 4 wires. 2 of them are for power the sensor with 8v (i am using an external power source for them) and 2 wires are giving the output in milivolts . For example sensor measure 100kg and each milivolt is 1kg.
I need your help on achiving this using rasp. I am thinking maybe i need an external device for this or can i do that only with rasp?
I want also mention that i would like to read sensors 10 times per second ...
Thanks in advance
Laurens-wuyts
Re: electrical precision measure
Mon Aug 31, 2015 11:51 am
For reading the voltages you'll need a Analog digital convertor, but for measuring millivolts you'll need a very precise one.
You'll also in some way need to reduce the 8V to 3.3V or 5V for the Analog digital converter. You can do this by using a simple voltage divider.
10 times a second is for a RPi (or every other microcontroller) no problem.
Laurens
lucian_v
Mon Aug 31, 2015 12:35 pm
Thanks a lot for answer.
Can you point me to a suitable dac for my project?
KLL
Mon Aug 31, 2015 1:03 pm
if you use a good amplifier
http://www.ti.com/lit/ds/symlink/ina125.pdf
you can use a normal ADC or even arduino ( connected by USB...) for it
http://edg.uchicago.edu/tutorials/load_ ... ematic.png
